Ivan Rocha Pasqueto
VAG-COM Version: Release 409.1-S
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01: Engine
Controller: 06A 906 032 S
Component: 1.8L R4/5VT 0004
Coding: 05500
Shop #: WSC 00082
1 Fault Found:
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00001
No fault code found.
Address 08: Auto HVAC
Controller: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00040
Shop #: WSC 00001
Address 15: Airbags
Controller: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 00001
1 Fault Found:
00532 - Supply Voltage B+
07-10 - Signal too Low - Intermittent
Address 17: Instruments
Controller: 8L0 920 933 Q
Component: KOMBI+WEGFAHRS. VDO D09
Coding: 03544
Shop #: WSC 00000
XXXXXXXXXXXXXXXXX AUZ7Z0A1989877
1 Fault Found:
01304 - Radio
49-00 - No Communications
Address 35: Centr. Locks
Controller: 8L0 862 257 G
Component: ZV-Pumpe, DWA, Funk D16
Coding: 13166
Shop #: WSC 00001
2 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00001
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 05500
Shop #: WSC 00082
1 Fault Found:
P0341 - 35-00 - -
Coding: 0018945
Shop #: WSC 00001
Coding: 00040
Shop #: WSC 00001
Address 15: Airbags
Coding: 00104
Shop #: WSC 00001
1 Fault Found:
Coding: 03544
Shop #: WSC 00000
1 Fault Found:
01304 - Radio
Coding: 13166
Shop #: WSC 00001
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00001
