[Vendido] Embreagem SPEC Stage III Carbono - para S3/TT
Jordaum
Aro 99
Vendo:
kit de embreagem SPEC Stage 3 - Carbono
Part Number: SA873
Aplicação:
Audi S3/TT 99-04 1.8T Fits:APY/AMK/BAM STAGE 3
Torque rating for this application: 517ft/lbs (72,38 kgf/m)
NÃO SERVE para A3 ou Golf, pois é de 240mm
Features a carbon semi-metallic 6 puck sprung hub disc that has been the leading puck clutch in drivability, life and torque capacity. This unit is designed for street and race cars that require an aggressive but streetable engagement and high torque capacity. The hub is double sprung with spring cover relieves for flexibility and heat treated components for strength and durability. Also available in 3 puck configuration. Great for street, drag, road racing, pulling, rallye and drift.
High clamp pressure plate
Carbon Semi-Metallic Friction Material
High torque sprung hub and disc assembly (application dependent)
Bearing and tool kit(application dependent)
Mais informações:
http://www.lmperformance.com/spec.asp
Fotos:
Valor R$2.200,00
Para importar um kit deste, com frete + imposto (60% II + 18% ICMS) fica mais de R$3.200,00
[]s,
