Passei o Vag-com e tive alguns erros, podem me ajudar?
eph2
Pessoal, tudo certo? Passei o Vag-com no meu carro hoje, e tive alguns erros. Passei o auto-scan do VCDS. Vou colocar todo o código abaixo, e ao lado dos erros vou descrever algumas infos, para ver se estou certo, ou errado.
Se puderem me ajudar, eu dou um reset e vemos como vai continuar.
Saturday,26,January,2013,20:29:12:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 77
VIN: Mileage: 59650km/37064miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 1010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 K HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0040
Revision: 5BH16--- Serial number:
Coding: 010310431C070160
Shop #: WSC 06314 000 00000
VCID: 3A712C317544B89
1 Fault Found:
012555 - Low Pressure Fuel regulation Perto desta data tive o problema de queimar uma bobina, pode ter relação?
P310B - 004 - Fuel Pressure Outside Specification
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 160
Mileage: 58440 km
Time Indication: 0
Date: 2012.12.04
Time: 11:32:29
Freeze Frame:
RPM: 831 /min
Load: 31.0 %
Speed: 0.0 km/h
Temperature: 81.0°C
Temperature: 37.0°C
Absolute Pres.: 920.0 mbar
Voltage: 13.335 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 070 1301
Revision: 04507000 Serial number: 00000611220688
Coding: 0000020
VCID: 2241F451FDD4D09
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021634
VCID: 73EFC11512AE091
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AC HW: 8P0 820 043 AC
Component: KlimavollautomatH19 0360
Revision: 082151 Serial number: 8P0820043AC
VCID: 6DDBD76D748ADF1
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 F HW: 8P0 907 279 F
Component: Bordnetz-SG H43 1201
Revision: 00H43000 Serial number: 00000006497477
Coding: E58E5F019014100000160000160000000008FE175A0500
Shop #: WSC 06314 000 08192
VCID: 40855ED91398E29
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H13 4260
Revision: 91H13426 Serial number: 003620G37WRA
Coding: 0071612
VCID: 428154D11D94F09
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 41835BDD1892EB1
Part No: XXXXXXXXXXX
Component: E0221 H07 0090
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 931 B HW: 8P0 920 931 B
Component: KOMBIINSTR. VDO H20 0570
Revision: D0H20004 Serial number: 224DF004009187
Coding: 0000118
Shop #: WSC 65536 773 2073257
VCID: 32610411AD34409
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 K HW: 1K0 907 951
Component: J533__Gateway H12 0170
Revision: H12 Serial number: 3300106B2202C0
Coding: 7F3F03C207002102
VCID: 2F670D65BE066D1
1 Fault Found:
01304 - Radio Não sei o problema, mas pode ser por isso que não mostra o nome das musicas no LCD do painel?
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 198
Mileage: 59421 km
Time Indication: 0
Date: 2013.01.09
Time: 19:48:54
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20004 Serial number: AUX7Z0FDFN6102
Shop #: WSC 00000 000 00000
1 Fault Found:
16346 - Control Module - ROM Error Esse foi o que mais me preocupou, estou com problema no imobilizador?
014 - Defective
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN2.lbl
Part No: 8P0 959 801 H
Component: Tuer-SG 020 0090
Coding: 0000216
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40) Fiquei impressionado, realmente estou com problema no botão de abrir e fechar o vidro. Fodástico esse VCDS
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.079 H07 1806
Shop #: WSC 02069 000 90108
VCID: 346D020957204E9
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 G
Component: KSG H08 0070
Coding: 9880202002186D098505488FC677
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
00956 - Key 2 Não sei se a segunda chave foi usada alguma vez, mas é possível configurar elas?
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH04 0180
Revision: 00003 Serial number: 30674696974047
VCID: F1E34B1DE8B2BB1
Address 52: Door Elect, Pass. Labels: 8P0-959-802-MIN2.lbl
Part No: 8P0 959 802 H
Coding: 0000216
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D7B272D646A8F1
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 195 A HW: 8P0 035 195 A
Component: symphony II US H59 0470
Revision: 13S Serial number: AUZ5Z4F6230278
Coding: 0001067
Shop #: WSC 06435 000 00000
VCID: 30650E19A338729
2 Faults Found:
00878 - Connection to Speaker Front Left Vou ter que verificar se o problema é no rádio, ou no falante, mas parece que ele está funcionando. Estranho.
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 222
Mileage: 59528 km
Time Indication: 0
Date: 2013.01.23
Time: 08:40:41
01305 - Databus for Infotainment Sem ideia do que pode ser, vcs tem ideia?
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 59421 km
Time Indication: 0
Date: 2013.01.09
Time: 19:48:53
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No: 8P4 959 801 D
Component: Tuer-SG 020 0070
Coding: 0000216
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No: 8P4 959 802 D
Coding: 0000216
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 H HW: 8P0 862 335 H
Component: FSE_255x BT H26 0290
Revision: 00000000 Serial number: 00000005062806
Coding: 0001295
VCID: 3B7F29357A7E811
1 Fault Found:
01304 - Radio Não saquei se é o bluetooth, ou se o carro tem aquelas comunicações de telefone dentro do carro. Vcs tem ideia?
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 198
Mileage: 59421 km
Time Indication: 0
Date: 2013.01.09
Time: 19:49:02
End ---------------------------------------------------------------------
Jordaum
Aro 99
Amigo, a primeira coisa a fazer é apagar todos os erros e dar uma volta, pois a maioria é erro que pode ter ficando de muito tempo.
Se depois aparecer ainda erro, vc pega o codigo e veridica no site da rosstech, tem quase tudo lá.
http://wiki.ross-tech.com/wiki/index.php/Audi_A3/S3_%26_A3_Cabriolet_(8P)
e procura os "Fault Codes".
Ex: [background=rgb(253, 250, 247)]012555[/background]
http://wiki.ross-tech.com/wiki/index.php/P310B/012555
Esses erros do "Rádio" não é pq vc trocou o symphony por uma central multimídia genérica não?
[]s,
Jordão
p.s O scan do Spb é muito mais completo que o do 8L mesmo.. Show de bola.
eph2
[]s,
Jordão
Blz, vou dar um clear e testar. Sobre o radio, ainda tenho o symphony II. Andei pesquisado um RNS-E, mas vou esperar pq a grana ta curta pra isso agora heheh.
mfractal
Stage II ECU + DSG Remap
eu pessoalmente acho RNS-E muito caro inclusive pq o GPS nunca vai dar certo no Brazil. A Audi simplismente nao tem mapas.
Minha opiniao - se for trocar, troca por um Alpine ou Pioneer 2-DIN ja com GPS imbutido, qualitdade de som bem melhor e, claro, opcao de instalar um modulo/speakers melhores.
Agora sobre os erros no VCDS, como o sr Jordaum ja falou - limpa todos os errors na tela autoscan.
Ai, tem esse ponto - ha erros que voltam imediatamente no proximo autoscan.
Esses errors tem que limpar acessando o certo modulo do erro e limpando de la.
Ai, scanea de novo, se algum erro reaparece, entrar no certo modulo do erro e limpa. Nao deve aparecer mas.
Depois anda alguns dias, e posta o novo scan.
eph2
Eu não sou o maior fã de som, então pra mim o sistema original já daria conta, eu queria mais pelos mapas, mas se tem essa questão, vou ficar com o Synphony II mesmo. Até pq gosto do interior todo original.
Sobre o scan, acabei de dar um reset e só persistiu do imobilizador. Nao dei o clear nele dentro do modulo, como você sugeriu, mas vou andar mais alguns dias e quando tiver o novo scan vou postar aqui.
Vlw por enquanto pessoal.
mfractal
beleza, faz assim entao.
Tenho ctz quase absoluta que o codigo da pressao do combustivel vai voltar logo. O Fault Frequency dele e 160, ou seja, ja aconteceu 160 vezes. Sobre outros, vamos ver..
Pergunta - durante o scan, quanto o vcds scanea o radio, aparece a mensagem DIAG no display. Acontece com o seu radio ?
eph2
O da pressão do combustível tenho duvidas, pq ele aconteceu 160 vezes, mas no período que deu pau na minha bobina, talvez esteja relacionado. Mas vou ficar de olho.
Sobre o radio, aparece o DIAGNOSE no radio e DIAG no painel.
O que mais me preocupa mesmo é do imobilizador. :/
Hoje fiz um passeio por uns interiores, estradas de chão e tudo mais, se for pra dar pau, vamos saber logo, amanha quero passar o scan de novo.
eph2
Pessoal, passei novamente o auto-scan do vag-com, e os erros voltaram a acontecer. Coloquei alguns comentários em vermelho ao lado. Me corrijam se eu estiver errado por gentileza.
Tuesday,29,January,2013,21:20:55:32264
Chassis Type: 1K0
VIN: Mileage: 59740km/37120miles
19-CAN Gateway -- Status: OK 0000
56-Radio -- Status: OK 0000
77-Telephone -- Status: OK 0000
1 Fault Found:
012555 - Low Pressure Fuel regulation Voltou a acontecer, mas pela quantidade de vezes que aconteceu, me parece estar ligado a um problema que acontece comigo na seguinte situação. Chego em casa por volta das 20:30, e só volto a ligar o carro às 8:30. Esta primeira "ligada" o carro sofre como se não tivesse gasolina na linha. Será que esse problema pode acontecer por essa "baixa" de pressão? Seria problema na bomba?
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Mileage: 59652 km
Time Indication: 0
Date: 2013.01.27
Time: 11:02:47
Freeze Frame:
RPM: 767 /min
Load: 25.1 %
Speed: 2.0 km/h
Temperature: 78.0°C
Temperature: 35.0°C
Voltage: 13.462 V
Coding: 0000020
Revision: 00H11001
Coding: 0021634
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
Coding: 0071612
Coding: 0014142
Coding: 0000118
1 Fault Found:
16346 - Control Module - ROM Error Esse continua me preocupando. Zerei o erro dentro do módulo, e ele voltou a acontecer. Acho que isso só consigo resolver numa concessária, certo?
014 - Defective
Coding: 0000216
1 Fault Found:
00912 - Window Regulator Switch; Front Left (E40) Continuo impressionado, esse vag-com é sensacional.
1 Fault Found:
00956 - Key 2 Eu estou usando a chave que me parece ser a 1, pelo visto ela é a 2. Será que pode ser pilha fraca no controle que está causando isso? eu achei uns 2 ou 20 tõpicos no fórum sobre configuração da chave, mas alguém pode confirmar se no 8P é da mesma forma?
Coding: 0000216
Coding: 0000012
Coding: 0001067
Coding: 0000216
Coding: 0000216
Coding: 0001295
Quer uma boa dica pra zerar esses erros
DESCONECTE A BATERIA
Oxe, como assim?
Explico. Se vc desconectar os bornes da bateria, o carro fica sem alimentação elétrica?
Então. O segredo dessa brincadeira é que faz a central RESETAR, voltar aos padrões originais
Faça assim. Meu carro tava com a luz da injeção ligada direto. Levei na css, acusou sonda lambda. Levei na primeira oficina, o mecânico tirou o cabo negativo da bateria e o positivo, deixou eles fora dos polos da mesma por 15 minutos(vc toma banho, assume o trono) e depois as colocou no lugar.
Results: A LUZ SUMIU ATÉ HOJE.
Faça isso. Tire os cabos da bateria(aproveite e dá uma limpada nela com uma escova macia e um pano úmido, pra tirar o pó), espere 15 minutos e depois a recoloque. Passe o VAG-COM outra vez. Eu te garanto que metade dos Fault-codes apagam.
mfractal
Bem, vamos um por um.
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 6
Mileage: 59652 km
Time Indication: 0
Date: 2013.01.27
Time: 11:02:47
Freeze Frame:
RPM: 767 /min
Load: 25.1 %
Speed: 2.0 km/h
Temperature: 78.0°C
Temperature: 35.0°C
Voltage: 13.462 V
Seguindo ross-tech http://wiki.ross-tec...hp/P310B/012555, e um problema bem conhecido. Resolução - troca de sensor de pressão de
combustível (G410). Vi que a peca custa 10$ la fora, então vale a pena trocar!
Dei uma pesquisada no ElsaWin e o # da peca e : 8k0973703.
Depois vou ver o resto dos erros.
eph2
Legal @mfractal. Procurei a peça na ECS Tuning, e me pareceu legal. Conhece a loja?
EDIT: Caraca, 54 doletas de frete, tá fora!! hehe Vou procurar outra loja!
EDIT2: Tenho um amigo nos EUA e vai trazer a peça pra mim hehe vai custar US$16,00.
Oxe, como assim?
Meus Caros,
O colega Mfractal deu show ai .. vou deixar ele terminar a bela explicação e solução dos erros .. Parabens !!!!!
Ao amigo bahiano tenho a seguinte consideração, realmente o procedimento que seu mexanico fez é valida ... realmente é uma forma de zerar os parametros ... mas a tal luz de injeção pode ter sido por outro fator e o caso de sonda lambda ainda pode esta acontecendo .. existe alguns erros que o vag tem alguma dificuldade de acusar certeiramente (MAF, SondaLambda...) então vc ainda pode está com um problema de sonda lambda em seu veículo ... só pra constar ...
eph2
Peça comprada, agora é só esperar chegar. Alguém sabe me dizer se tem algum tutorial aqui no clube de como tirar aquela tampa do motor? Acredito que eu mesmo consigo trocar o sensor.
Aproveitando, e já abusando @mfractal, você conseguiu ver de mais algum erro?
mfractal
1 Fault Found:
014 - Defective
caro @eph2, infelizmente pelo que eu li e vi nos forums "gringos", e tambem no site ross-tech esse tipo de erro normalmente significa que tem que trocar esse control module (immobilizer). Que no seu caso e troca do Instrument cluster com part number 8P0 920 931 B (immobilizer embutido dentro do instrument cluster). Para troca-lo tem que seguir o seguinte procedimento.
Ache um no site eBay alemão
Fault Codes like this can usually not be repaired since they are stored after the Control Module did not pass it's internal Self Test. Even though the official Repair Manuals suggest replacing the Control Module in such a case, there may be specialized Companies repairing Modules like this.
Mas, se tudo esta em ordem e funcionando, eu deixaria de jeito que ta.
Coding: 0000216
1 Fault Found:
O controlador não da porta do condutor não funciona ? E só trocar..
Acho que e essa peca : http://www.ecstuning...witch/ES393425/
1 Fault Found:
Esse erro pode ser relacionado com o erro no Immobilizer. Ambos chaves funcionam para abrir/fechar/ligar o carro ?
eph2
Valeu @mfractal Era exatamente o que eu imaginava.
Sobre o imobilizador, a principio não tenho problema nenhum, pelo visto ele apenas não funciona. A minha chave as vezes não abre o carro, mas eu coloco na fechadura, abro o carro, e logo depois ela volta a funcionar, tenho dúvidas se não pode ser a pilha também.
Sobre ligar o carro, testei até agora só com uma chave, mas nunca falhou. Ele demora um pouco para ligar (como se o motor estivesse pesado), mas sempre ligou.
Uma dúvida, você tem ideia do pq pode ter dado pau no imobilizador?
PS: Apesar dos pesares estou adorando brincar com o Vag-com, já configurei alguns itens seguindo uns tutoriais que achei na net. Quando tiver testado alguns, e visto que realmente funcionam, vou fazer um DIY aqui para o fórum.
Valeu pelas dicas! :D
