Part Number
Olá pessoal, não encontrei esse conteúdo no forum, resolvi contribuir...
Coloquei apenas os que me interessou, caso alguém precise de algum é só solicitar, acredito que o site abaixo tem todos, o que pega que os itens no site estão em russo... t:
Conteúdo original: http://autopartmaster.com
[01] 8L0823029C bonnet
[02] 8L0823301B bonnet hinge left
(02) 8L0823302B bonnet hinge right
[03] N 01023911 hexagonal head bolt (M8X18)
[04] N 0115332 washer (A7,4X14,5X1,6)
[05] 8L1823531A bonnet lock cable (1825MM)
(05) 8L2823531A bonnet lock cable (1795MM)
[06] 893823595A retainer
[07] N 90653901 retaining clip (C16X7,6)
[08] 1H1823533 handle for bonnet lock cable (lhd)
[---] 1H1823533 01C satin black
(08) 1H2823533 handle for bonnet lock cable (rhd)
[---] 1H2823533 01C satin black
[09] N 90548801 panel screw (4,8X19)
[10] 811807577C insert nut
[11] 8L0823480B arrester hook
(11) flap - lock
[12] N 90839901 domed cap nut (M6)
[13] 8L0823725A gasket
(13) 8L9823711 gasket adapt with workshop equipment left/right (S3)
[14] 8L0823733 sealing piece
[15] 8L0823737 gasket left front
(15) 8L9823711 gasket front
[16] 8L0823738 gasket right front
[17] 8L0823723 seal for water box
[18] 811803583C plug (29,6)
[19] 8D0823481 stop buffer
[20] 443803583M drain valve (14,5)
[21] 8L0823359 gas-filled strut
[22] 357823591 grommet (18/4MM)
(01) 8L0827023M tailgate / boot lid
(01) 8L9827023F tailgate / boot lid for vehicles with spoiler
[01] 8L0827023K tailgate / boot lid
(01) 8L9827023D tailgate / boot lid for vehicles with spoiler (S3)
(01) 8L9827023D tailgate / boot lid for vehicles with spoiler 8L-1-400 000 (BRA:S3)
(01) 8L9827023F tailgate / boot lid for vehicles with spoiler 8L-2-000 001 (BRA:S3)
[---] 3BE813297 pipe clip (BRA:S3)
[02] 8D9827299 bonnet hinge
[03] 4A9827341A sealing washer
[04] N 90091301 washer 8,4X35X3
[05] N 90107604 washer 8,2X18X2
(05) N 90477201 washer B8,4X33X2
[06] N 01100830 hexagonal nut (M8)
[07] N 90107604 washer (8,2X18X2)
[08] N 01024118 hexagonal head bolt (M8X22)
(08) N 01024016 hexagonal head bolt (M8X20)
[09] 895827439B ball pin
[10] 8D9827552F gas-filled strut _ F >> 8L-2-090 000* (470N)
(10) 8D9827552H gas-filled strut _ F 8L-2-090 001>>* (460N)
[10] 8D9827552G gas-filled strut _ for vehicles with reduced flap opening angle (500N)
[11] 443823397 clips _ pressure pipe
(11) 1H5827905 securing clip _ piston rod
[12] 8L0827705G gasket for flap
[13] 8L9827711 retaining profile _ for vehicles with spoiler (S3)
[14] 8D9827279A hinge cover
[---] 8D9827279A 01C satin black
(14) 8D9827280A hinge cover
[---] 8D9827280A 01C satin black
[15] N 90775001 torx socket head panel screw (4,8X16)
[16] N 90648101 rivetted cap nut (M6/0,7-3B)
[17] 8D5827713A plug (12X4MM)
[18] 8D5827249 stop buffer
[19] 8L0827249 stop buffer, adjustable
[20] N 0162023 cup rivet (AK4X8X8,2)
[21] 3B0827633C base (440X90X1,5)
[22] 6X0827951A plug (7,5/25)
[23] N 90648101 rivetted cap nut (M6/0,7-3B)
[24] 8L0827113 trim for licence plate
[---] 8L0827113 3FZ satin black
[25] N 0141395 fillister hd. bolt (M6X12)
[26] N 0122265 spring washer (B6X12X0,5)
[27] 113119583 caged nut (M6)
[01] 8L0845099Q windshield glass (laminated) with tinted zone (PR-4GH)
(01) 8L0845099S windscreen glass (laminated) with tinted zone and view window (PR-4GP)
[02] 8L0853306 moulding frame (lower)
[02] 8L0853306 01C satin black
[03] 8D0845127B filler piece
[03] 8D0845127B 01C satin black
[04] 8L0845131A cover strip upper
[05] 8L0845237 distance piece
(09) 8L0845453 clamping strip
[09] 8L0845454 clamping strip
[10] 701845543A retaining plate for rear view mirror, interior
[11] 443845631A distance piece (19X12X55)
(12) 8L0854327 water deflector
[12] 8L0854328 water deflector
[13] N 90787802 cup rivet (AK3,2X6,5)
[19] D 000703A1 1 set of glass-metal adhesive (0,3G)
[20] 357853999A cutting cord for removing windows (1,25X6000)
[21] DA 004600A2 2k-window adhesive set (400ML)
[23] D 00920002 primer for glass and paint (10ML)
[01] 1J0122051H water hose (radiator > water pump)
[02] 6Q0122291F quick coupling piece
[03] N 90765301 round seal (32X4-N)
[04] 1J0121142 retaining spring
[07] N 90655801 spring-type clip (40X12)
[08] 1J0121093C retainer
[10] 06A121065AP water pipe
[11] N 90365302 round seal (20X3)
[12] N 90175203 hexagon nut, shouldered (M6)
[13] N 0447273 allen key head bolt (M10X16)
[14] 1J0121086AA water hose (flange > oil cooler > water pipe)
[16] 1J0121096AF water hose (adapter > water pipe) (manual gearbox)
[17] 1J0122447EG water hose (reservoir > throttle valve housing > junction piece)
[17A 1J0121093G retainer
[17B 1J0121093J retainer
[17C N 10436201 retainer for water hose (A3-14XC13-6,5)
[18] 1J0121058AC water hose (at fluid cooler > water pipe) (automatic)
[19] 1J0121096K water hose (gearbox oil cooler > adapter) (automatic)
[20] 8N0122101A water hose (flange > radiator)
[21] 1J0121087C junction
[22] 1J0122291 quick coupling piece
[29] 1J0122073A water hose with quick coupling piece (heat exchanger > water pipe)
[30] 1J0122291D quick coupling piece
[32] 1J0122157Q water hose with quick coupling piece (flange > heat exchanger)
[33] 1J0122291B quick coupling piece
[35] 1J0121447G water hose (throttle valve housing > adapter)
[36] 1J0121109B water hose (expansion chamber > water pipe)
[42] N 10292201 spring-type clip (A14X12)
[43] N 90655501 spring-type clip (23X12)
[44] N 90655601 spring-type clip (27X12)
[45] N 90655701 spring-type clip (32X12)
[46] N 90655801 spring-type clip (40X12)
[47] N 0209022 cable tie (6X246)
[01] 06A133210B variable intake manifold
[02] 06A133206C intake manifold (lower)
[03] 06A133374K vacuum hose
[04] 06A133398D seal
[05] 06A133557H seal (56,8X2,6X6,7)
[06] 1J0906283B solenoid change-over valve
[08] N 0150825 hexagon nut, shouldered (M6)
[09] 06A133557G seal (66X2,6X6,7)
[10] N 10190701 allen key head bolt (combi) (M6X35-S4-N)
[11] 06A133062L throttle valve control unit
[12] 06A129763A rubber mounting
[13] 06A129289C hexagonal head bolt
[14] N 90807501 washer (A10,5X22X1,5)
[15] 037906283D solenoid valve
[16] N 90824901 torx socket head panel screw (5X14-Q)
[17] 06A129061C vacuum unit
[18] N 10433101 hexagon socket head bolt with collar (M6X48)
[19] 06A133806 clip
[20] N 10427501 retainer (A2-7XC12-6,5)
[21] 06A133653A shift rod
[22] N 10091101 pipe clip (7,5-9)
[23] 06A201449 clips
[24] 06A133231G support
[25] 431820667 grommet
[26] 049103389 cap (8MM)
(26) 1J0133366G connecting hose
[27] N 10258201 pipe clip (AL12-22)
(27) N 10292201 spring-type clip (A14X12)
[28] N 10172501 allen key head bolt (combi) (M6X22-S4-SP)
[29] N 90355902 allen key head bolt (combi) (M8X30)
[---] N 0203535 hose in coils of 5m 'order unit 5' (3,5X2)
[30] shorten to: (91MM)
[32] shorten to: 480MM)
[33] shorten to: 350MM)
[34] 06A133241 connecting pipe 1
[35] 06A133241A connecting hose 1
[36] 06A133241B connecting hose 1
[37] 06A133241C connecting hose 1
[38] 06A133241D connecting hose 1
[39] 06A133241E connecting hose 1
[40] 06A905291 non-return valve 1
[41] 06A133460 retainer 1
[42] 06A141730 toothed lock washer 1
[43] 058133753B suction jet pump 1
[44] N 0245281 pipe clip LC8-12 2
[45] N 10196901 pipe clip 7X14,8 1
[46] N 10258201 pipe clip AL12-22 6
[47] N 10201901 pipe clip 7X19,4-22,6 1
[48] 06A131501G exhaust recirculation valve 1
[49] 06A131514D connecting pipe
[50] 06A131547D gasket
[51] 06A131547J gasket
[52] 06A131547F gasket
[53] N 90355902 allen key head bolt (combi) M8X30)
[54] N 10226102 hexagon socket head bolt with collar (M6X16)
[56] 1J0131057A vacuum hose
[57] N 01508311 hexagon nut, shouldered (M8)
[58] N 0209022 cable tie 6X246 X
[59] 06A133374C hose 1
[60] 06A133374L hose 1
[61] 113201943B t-piece 4/4/4 2
[62] 06A820675 non-return valve 1
[63] 06A133374A angled hose 1
1 06A109108K toothed belt cover
2 048109150 spring clamp
3 06A109147F toothed belt cover
4 toothed belt pulley
5 06B109119A toothed belt (Z=150)
6 06A109175B toothed belt cover (lower)
7 N 10156305 hexagon head bolt c/w shoulder (M6X12)
8 06B109243D tensioning roller
(9) 06B109477 belt tensioning damper
10 N 90945001 hexagon socket head bolt with shoulder (M7X21,5-SP)
11 06B109244 relay roller
1 1J0803403 repair plate - side member
2 1J0803404 repair plate - side member
3 1J0803215A mounting
(3) 1J0803216A mounting
4 8L0803421A wheel housing inner part
(4) 8L0803421D wheel housing inner part (quattro)
5 8L0803422A wheel housing inner part
(5) 8L0803422D wheel housing inner part (quattro)
- 811807577C insert nut
(6) 1J6801771 mounting for subframe left (quattro)
6 1J6801772 mounting for subframe right (quattro)
7 1J0803481B housing for fuel filler neck
(12) 8L0803491B connecting plate for longitudinal member (quattro)
12 8L0803492B connecting plate for longitudinal member (quattro)
14 8L0803501A longitudinal member
(14) 1J0803501C longitudinal member (quattro)
15 1J6803502F longitudinal member
(15) 1J0803502C longitudinal member (quattro)
- D 000111A2 2k-insert foam
17 1J0803520 reinforcement for side member
18 1J0803531 cross member
(18) 1J0803531C cross member (quattro)
- N 90402801 locking cover (16,5X32,5X18)
20 1J0803545 bracket for exhaust system
22 1J0804298 bracket for heat shield
28 1J0813119B carrier panel left lower
28 1J0813119A carrier panel left lower (quattro)
29 1J0813120B carrier panel right rear
29 1J0813120A carrier panel right rear (quattro)
[01] ---------- (820-20)
[02] ---------- (820-20)
[03] 1H0819056 double stud with hexagon drive
[04] 321819059 clips
[05] 1H0819165 gasket
[07] 1J0819498 grommet
[08] ---------- (819-20)
[11] 191819370 gasket
(12) 321819017 gasket (680X8X10)
[13] 1H0819019 gasket _ heat exchanger
[14] N 90666101 cable tie _ hole/sheet metal thickness (4,5X200)
[15A 1J0819644A filter element with odor and harmful substances filltration
[15B 1J0819648 frame filter element
[16] 1J1819640B filter housing (lhd)
(16) 1J2819640A filter housing (rhd)
(17) 1H0819943 screw
[18] 1J1819021C blower (lhd)
(18) 1J1819021C blower _ (lhd)
(18) 1J2819021C blower (rhd)
(18) 1J2819021C blower _ (rhd)
[20] 6N1815645A covering _ FUER POLLENFILTER (lhd)
(20) 6N2815645 covering (rhd)
[21] 8E0260749 round seal (10,8X1,82)
[22] 8E0260749D round seal (14X1,8)
[24] 1H0820119A water drain valve
[26] 1H0820133 gasket
[27] 1J1820139 gasket (lhd)
(27) 1J2820139 gasket (rhd)
[28] 1J0819022A series resistor
[31] 1H1820281 reinforcement plate (lhd)
(31) 1J2820281 reinforcement plate (rhd)
(34) 8L1819593 intermediate layer (lhd)
(34) 8L2819593 intermediate layer (rhd)
(36) 6N0820679C expansion valve (R134A)
[37] 1H0820692 insulating piece
[---] 1H0820692 01C satin black
[39] 191820845 tensioning strap
[40] N 10157801 cheese head bolt (M5X48)
[46] N 10424101 hexagon head panel screw (4X16H)
[51] N 90216201 hex. nut (M6)
[53] 191837270 hexagon nut, shouldered (M5)
[54] N 0164031 spring-type clip
[55] 1H0819019 gasket _ heat exchanger
[57] N 90549601 hexagon head bolt (combi) (D4X14)
1A 8L4867173 armrest
8L4867173 1VE maritime blue
8L4867173 24A soul (black)
8L4867173 35J jive (grey beige)
(1A) 8L4867174 armrest _ right lhd
8L4867174 1VE maritime blue
8L4867174 24A soul (black)
8L4867174 35J jive (grey beige)
(1A) 8L4867173A armrest
8L4867173A 1VE maritime blue
8L4867173A 24A soul (black)
8L4867173A 35J jive (grey beige)
(1A) 8L4867174A armrest
8L4867174A 1VE maritime blue
8L4867174A 24A soul (black)
8L4867174A 35J jive (grey beige)
1B 8L4868189 compensating piece
8L4868189 2XE maritime blue
8L4868189 24A soul (black)
8L4868189 35J jive (grey beige)
(1B) 8L4868190 compensating piece
8L4868190 2XE maritime blue
8L4868190 24A soul (black)
8L4868190 35J jive (grey beige)
1C N 10415901 torx socket head panel screw (4X12-Q)
(2) 8L3867171 handle recess upper part for models with electric windows and electrically opearted and heated rear view mirror
8L3867171 2XE maritime blue
8L3867171 43Y jive (grey beige)
8L3867171 7PE soul (black)
(2) 8L3867171H handle recess-upper part _ for models with electric windows and electrically opearted and heated rear view mirror
8L3867171H 1LQ black pianopaint
(2) 8L3867171B handle recess-upper part _ for vehicles with electric windows and rear view mirror electrically operated, folding and heated
8L3867171B 2XE maritime blue
8L3867171B 43Y jive (grey beige)
8L3867171B 7PE soul (black)
(2) 8L3867171J handle recess-upper part _ for vehicles with electric windows, electrically operated seats and rear view mirror electrically operated and heated (S3)
8L3867171J 1LQ black pianopaint
(2) 8L3867171G handle recess upper part for vehicles with electric windows, electrically operated seats and rear view mirror electrically operated and heated
8L3867171G 2XE maritime blue
8L3867171G 43Y jive (grey beige)
8L3867171G 7PE soul (black)
(2) 8L3867171K handle recess-upper part _ for models with electrically operated windows left rhd 1 _
8L3867171K 1LQ black-pianopaint _ _ -AS,AT,AU,AV, _ _
(2) 8L3867172G handle recess-upper part _ for models with electrically operated windows
8L3867172G 2XE maritime blue
8L3867172G 43Y jive (grey beige)
8L3867172G 7PE soul (black)
(2) 8L3867172K handle recess-upper part _ for models with electrically operated windows (S3)
8L3867172K 1LQ black pianopaint
(2) 8L3867172A handle recess-upper part _ for vehicles with rear view mirror electrically operated and heated
8L3867172A 2XE maritime blue
8L3867172A 43Y jive (grey beige)
8L3867172A 7PE soul (black)
(2) 8L3867172H handle recess-upper part _ for vehicles with rear view mirror electrically operated and heated
8L3867172H 1LQ black pianopaint
(2) 8L3867172B handle recess upper part for vehicles with electric windows and rear view mirror electrically operated, folding and heated
8L3867172B 2XE maritime blue
8L3867172B 43Y jive (grey beige)
8L3867172B 7PE soul (black)
(2) 8L3867172J handle recess upper part for vehicles with rear view mirror electrically operated and heated
8L3867172J 1LQ black pianopaint
(2) 8L4867163 trim for armrest
8L4867163 2XE maritime blue
8L4867163 43Y jive (grey beige)
8L4867163 7PE soul (black)
(2) 8L4867163A trim for armrest
8L4867163A 2XE maritime blue
8L4867163A 43Y jive (grey beige)
8L4867163A 7PE soul (black)
(2) 8L4867164 trim for armrest comprising
8L4867164 2XE maritime blue
8L4867164 43Y jive (grey beige)
8L4867164 7PE soul (black)
(2) 8L4867164A trim for armrest comprising
8L4867164A 2XE maritime blue
8L4867164A 43Y jive (grey beige)
8L4867164A 7PE soul (black)
- 8L4868191 switch bracket
2A 8D0867059 clips
3 N 90347402 oval head panel screw (E4X12-K)
4 893867199 snap nut (B4,2X25)
5 N 90312901 oval head panel screw (combi) (B4,2X22)
6 8L3867195A handle recess
8L3867195A 2XE maritime blue
8L3867195A 43Y jive (grey beige)
8L3867195A 7PE soul (black)_
(6) 8L3867196A handle recess
8L3867196A 2XE maritime blue
8L3867196A 43Y jive (grey beige)
8L3867196A 7PE soul (black)
7 433862195 screw 4,2X16
1 8L9601025A wheel disc 'alum' for winter tires (JX16H2 ET31) (S3R-7BV)
8L9601025A Z17 avus-silver
2 8N0601025C wheel disc 'alum' (JX16H2 ET31) (PR-3DR)
8N0601025C Z17 avus-silver
3 8L0601025AD wheel disc 'alum' (JX17H2 ET42) (PR-CE9)
8L0601025ADZ17 avus-silver
4 8L0601025T wheel disc 'alum' (JX17H2 ET38) (PR-C2G)
8L0601025T Z17 avus-silver
5 8L0601025AC wheel disc 'alum' (JX17H2 ET38) (PR-CC3)
8L0601025AC1H7 silver
6 8L9601025 wheel disc 'alum' (7,5JX17H2 ET32) (PR-C4F)
8L9601025 Z17 avus-silver
(5) 8N0601025S wheel disc 'alum' (JX18H2 ET33) (PR-CL4)
8N0601025S 1H7 silver
9 8D0601165E wheel cap
8D0601165E Z17 avus-silver for wheel disc
10 4B0601170 wheel cap
4B0601170 Z17 avus-silver for wheel disc
11 8N0601170 wheel cap
8N0601170 Z33 burnished aluminium for wheel disc
12 8D0601165K wheel cap
8D0601165K 1H7 silver for wheel disc
14 b 8D0601139D wheel bolt (M14X1,5X27)
15 8D0601139F wheel bolt, anti-theft with adapter (M14X1,5X27,5)
b 8D0601139F 000 code key .....000
b 8D0601139F 001 code key .....001
b 8D0601139F 002 code key .....002
b 8D0601139F 003 code key .....003
b 8D0601139F 004 code key .....004
b 8D0601139F 005 code key .....005
b 8D0601139F 006 code key .....006
b 8D0601139F 007 code key .....007
b 8D0601139F 008 code key .....008
b 8D0601139F 009 code key .....009
16 8D0698137B set of wheel bolts, anti-theft (M14X1,5X27,5)
b 8D0698137B SBV (self-service pack)
17 321601173A cap - wheel bolt (16,7X18MB)
321601173A Z37 grey-metallic
18 8D0601173D cap - wheel bolt _ for: _ wheel bolt, anti-theft
* 8D0601173D Z37 grey-metallic
19 * 8D0012244A removal tool
(1) 8D0857607F grab handle, folding
8D0857607F E59 platinum
8D0857607F 1RS twist (beige)
8D0857607F 4PK soul (black)
8D0857607F 47F royale blue
(2) 8D0857607G grab handle, folding
8D0857607G E59 platinum
8D0857607G 1RS twist (beige)
8D0857607G 4PK soul (black)
8D0857607G 47F royale blue
(2) 8D0857608C grab handle, folding
8D0857608C E59 platinum
8D0857608C 1RS twist (beige)
8D0857608C 4PK soul (black)
8D0857608C 47F royale blue
3 N 0139694 oval head panel screw (B4,8X16)
(3) N 10473301 torx socket fillister hd. bolt for veh. with curtain airbag (AM5X55-E-W)
4 8D0857610 expanding nut
5 895857621 cover cap
895857621 E59 platinum
895857621 1RS twist (beige)
895857621 4PK soul (black)
895857621 47F royale blue
(11) 8D0857551H sun visor with mirror and cover
8D0857551H 46E royale blue
8D0857551H 86K platinum
(11) 8D0857551P sun visor with mirror and cover
8D0857551P 46E royale blue
8D0857551P 86K platinum
8D0857551P 85P soul (black)
8D0857551P 89Q twist (beige)
(13) 8D0857552H sun visor with mirror and cover
8D0857552H 46E royale blue
8D0857552H 89Q twist (beige)
(13) 8D0857552P sun visor with mirror and cover
8D0857552P 46E royale blue
8D0857552P 85P soul (black)
8D0857552P 86K platinum
8D0857552P 89Q twist (beige)
(15) 8D0857551F sun visor with mirror and cover for models with illuminated vanity mirror
8D0857551F 46E royale blue
8D0857551F 85P soul (black)
(15) 8D0857551Q sun visor with mirror and cover for models with illuminated vanity mirror
8D0857551Q 46E royale blue
8D0857551Q 85P soul (black)
8D0857551Q 86K platinum
8D0857551Q 89Q twist (beige)
(15) 8D0857551K sun visor with mirror and cover for models with illuminated vanity mirror
8D0857551K 46E royale blue
8D0857551K 85P soul (black)
8D0857551K 86K platinum
8D0857551K 89Q twist (beige)
(15) 8D0857551T sun visor with mirror and cover
8D0857551T 46E royale blue
8D0857551T 85P soul (black)
8D0857551T 86K platinum
8D0857551T 89Q twist (beige)
(17) 8D0857552F sun visor with mirror and cover for models with illuminated vanity mirror
8D0857552F 46E royale blue
8D0857552F 85P soul (black)
8D0857552F 86K platinum
8D0857552F 89Q twist (beige)
(17) 8D0857552Q sun visor with mirror and cover for models with illuminated vanity mirror
8D0857552Q 46E royale blue
8D0857552Q 85P soul (black)
8D0857552Q 86K platinum
8D0857552Q 89Q twist (beige)
(17) 8D0857552K sun visor with mirror and cover for models with illuminated vanity mirror
8D0857552K 85P soul (black)
8D0857552K 86K platinum
8D0857552K 89Q twist (beige)
(17) 8D0857552T sun visor with mirror and cover for models with illuminated vanity mirror
8D0857552T 46E royale blue
8D0857552T 85P soul (black)
8D0857552T 86K platinum
8D0857552T 89Q twist (beige)
20 N 0139649 oval head panel screw (ST4,2X16-C)
(21) 443857561H bracket for sun visor
443857561H E59 platinum
443857561H 1RS twist (beige)
443857561H 4PK soul (black)
443857561H 47F royale blue
23 N 0139649 oval head panel screw (ST4,2X16-C)
(25) 443857563A cover cap bracket for sun visor
443857563A E59 platinum
443857563A 1RS twist (beige)
443857563A 4PK soul (black)
443857563A 47F royale blue
(30) 8D0858555 sun vizor
8D0858555 E59 platinum
8D0858555 1RS twist (beige)
8D0858555 4PK soul (black)
8D0858555 47F royale blue
33 N 01396626 oval head panel screw (4,2X13STC)
35 8L0858556 bracket for sun visor
(35) 8L0858556A bracket for sun visor for vehicles with automatic anti-dazzle
[01] 8L0863243K centre console front
[01] 8L0863243K 3ZQ maritime blue
[01] 8L0863243K 42R jive (grey beige)
[01] 8L0863243K 6PS soul (black)
[02] N 90356203 snap nut
[03] N 90729001 shouldered bolt (M5X16-SP)
[07] trim for radio aperture
[08] 8L0863263K trim for console for vehicles with manually regulated heater (PR-4A0,9AA)
[08] 8L0863263K 5PR soul (black)
[09] 8L0863263L trim for console for vehicles with manually regulated heater for vehicles with seat and backrest heater element (PR-4A3,9AA)
[09] 8L0863263L 5PR soul (black)
[10] 8L0863321 trim (PR-5TC)
[10] 8L0863321 5PR soul (black)
(10) 8L0863321A trim _ for models with wood inlay
[10] 8L0863321A 1LQ black-pianopaint (PR-5TL)
[10] 8L0863321A 5TQ vavona (brown) (PR-5ME)
(11) 8L0863077 shelf/stowage compartment (PR-5TC)
[11] 8L0863077 B98 satin black
(11) 8L0863077D shelf/stowage compartment (PR-5TC)
[11] 8L0863077D 5PR soul (black)
[11] 8L0863077A shelf/stowage compartment for models with wood inlay (PR-5ME/5TL)
[11] 8L0863077A 4PK soul (black)
[11] 8L0863077E shelf/stowage compartment for models with wood inlay (PR-5ME/5TL)
[11] 8L0863077E 4PK soul (black)
[12] 8L0863079A trim _ shelf/stowage compartment _ for models with wood inlay
[12] 8L0863079A 1LQ black-pianopaint (PR-5TL)
[12] 8L0863079A 5TQ vavona (brown) (PR-5ME)
[02] 8L1713139G selector lever handle (leatherette)
[02] 8L1713139G MMX jive (grey beige)
[02] 8L1713139G MMW soul (black)
(02) 8L1713139H gearstick grip (leather)
[02] 8L1713139H MDA soul (black)
[02] 8L1713139H MDD jive (grey beige)
(02) 8L2713139G selector lever handle (leatherette)
[02] 8L2713139G P40 jive (grey beige)
[02] 8L2713139G MMX jive (grey beige)
[02] 8L2713139G MMW soul (black)
(02) 8L2713139H gearstick grip (leather)
[02] 8L2713139H MDA soul (black)
[02] 8L2713139H MDD jive (grey beige)
[03] 8L0713169B sleeve
[03] 8L0713169B 3Q7 aluminium
[05] 8L1713111A covering
[05] 8L1713111A 3Q7 aluminium
(05) 8L2713111A covering
[05] 8L2713111A 3Q7 aluminium
[06] 8L0713187A cover strips
[07] N 90561701 oval head panel screw (E3X9,5)
[08] 8L1713239A fibre optic conductor
(08) 8L2713239A fibre optic conductor
[09] 8L0713189A guide
[10] 1J0713091A cover
[11] 1J0713848 panel screw
[12] 1J0713075 gasket
[13] 1J0713061A gearshift housing
[14] 1J0713297 round seal
[15] 1J0713367 washer
[16] 1J0713525 locking lever
[17] 1J0713318 contact plate
[19] N 0195334 hexagon head bolt c/w shoulder (M8X20)
[20] 1J0713229 bearing pin
[21] 1J0713076 gasket
[22] N 0124331 lock washer (3,2)
[23] 1J0713417 roller
[24] 1J0713123C gearshift lever
[25] 1J0713135 detent spring
[26] N 0121272 shake-proof washer (A6,4)
[27] N 0141387 fillister hd. bolt (M6X10)
[28] N 90413004 hexagonal head bolt (H6X19)
[29] 1J0713181A locking backet
[30] 1J0713128 contacts
[31] 1J0713317 retainer
[34] 1J0713126 detent pin
[35] 1J0713285 rubber washer
[36] N 01152520 washer (A8,4X16X1,6)
[37] N 0221468 hexagon nut, self-locking (VM8)
[38] N 90183802 hexagon nut, shouldered (M8)
[39] N 90685101 bracket for connector housing
[40] 8L0713303 locking cable
[41] 1J0713231 securing spring
[42] 1J0713265A wire cable
[43] 1J0711280 securing clip
[50] G 052142A2 poly lubricant (400G)
(11) flap - lock
[19] 06A133806 clip
2A 8D0867059 clips
