Ajuste Básico injeção Audi 8P
Fala Galera ,
esses dias o @[member="della"] tomou iniciativa postou para vocês ensinando o ajuste da transmissão 02E , DSG .. créditos a ele quem lembrou disso..
bastante gente as vezes desliga bateria ou desconecta algum conector do motor .
ai vai a dica faça um ajuste básico do motor completo ..
são os mesmos procedimentos do que tenho da audi .. esta na mesma fonte que o Della extraio o da transmissão !
tem ate um video bacana ,,
este ajuste regula todos os parametros de injeção , recalibra o modulo ..
Basic Setting Throttle Body
Prerequisites:
  • Ignition ON
  • Engine OFF
  • System voltage at least 11.0 V.
[Select]
[01 - Engine]
[Basic Settings - 04]
Group 060
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Wait until Field 4 shows "ADP. O.K.".
[Done, Go Back]
[Close Controller, Go Back - 06]
  • Switch Ignition OFF.
Kick Down
Prerequisites:
  • Ignition ON
  • Engine OFF
[Select]
[01 - Engine]
Group 063
[Go!]
[ON/OFF/Next]
Press the pedal to the floor and hold it there for at least 2 seconds.
Observe Field 4, once the adaptation is successfully done it should show "ADP. O.K.".
[Done, Go Back]
Fuel Pump
Prerequisites:
  • Ignition ON
  • Engine ON
[Select]
[01 - Engine]
Group 103
[Go!]
[ON/OFF/Next]
[Done, Go Back]
Intake Manifold Runner
Prerequisites:
  • Ignition ON
  • Engine OFF
[Select]
[01 - Engine]
Group 142
[Go!]
[ON/OFF/Next]
[Done, Go Back]
  • Switch Ignition OFF for at least 60 seconds.
Notes:
  • The newer timing chain driven engines which were phased in during model year 2009 the engine may need to be running at idle. Common examples of these engine codes include CCTA, CBFA and CCTA.
  • Never run Basic Settings with the IMRC motor linkage disconnected from the intake manifold. It may damage the new part.
Readiness
Prerequisites:
  • Ignition ON
  • Engine at idle
  • No fault codes
[Select]
[01 - Engine]
Group 200
[Go!]
[ON/OFF/Next]
Firmly press Brake Pedal and Throttle Pedal (Full Throttle) at once to activate the basic setting.
Field 1 shows the steps counter, which counts down to 0 - then setting readiness is done.
Stay on the pedals as long as the procedure lasts.
[Done, Go Back]
Special Functions Checking Fuel Pressure
Prerequisites:
  • Ignition ON
  • Engine ON (Idle)
  • Coolant Temperature at least 80 °C
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 103
[Go!]
Field 1: Fuel Pressure (Low), Specification: 2800...7200 mbar
Field 2: Fuel Pump Adaptation, Specification: -1000...+1000 %
Group 106
[Go!]
Field 2: Fuel Rail,Pressure (actual): 55% or below is normal at idle
  • 55% to 60% is a gray area, it may be okay, but may indicate a problem
  • Above 60% implies there is a failure or restriction
    Causes of low pressure can include kinks or restrictions in fuel lines
  • Fuel filter issues including restricted/clogged or incorrect part number
  • Failing lift pump in fuel tank. We have seen numerous cases of sub-standard quality "factory" replacements in "factory boxes" that were obtained from aftermarket sources and are not sourced from official dealers. This led to troubleshooting problems that were solved by installing correct factory parts. We encourage customers to only install lift pump and fuel filter sourced directly from a VW/Audi dealer.
Group 140
[Go!]
Field 3: Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Increase the Engine Speed while checking this value, the Pressure has to rise with the Engine Speed.
Group 230
[Go!]
Field 1: Specified Fuel Rail Pressure (High)
Field 2: Actual Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Field 3: Deviation between specified and actual fuel pressure, Specification: max. 5.0 bar
  • This video may be helpful:
http://www.youtube.com/watch?v=jThQVzYFbVo
[Done, Go Back]
