[A3 8P - Log de Falha VAG] Problemas e soluções
lcsanches
Puxa, o meu também está com essa mesma falha:
Tuesday,08,October,2013,20:53:19:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Address 01: Engine Labels: 06J-907-115-CCZ.clb
Control Module Part Number: 8P0 907 115 BA HW: 8P0 907 115 Q
Component and/or Version: 2.0l R4/4V TFSI 0020
Software Coding: 0103100C1C070160
Work Shop Code: WSC 06314 000 00000
VCID: 72E1C4116DB4009
1 Fault Found:
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100000
Fault Priority: 0
Fault Frequency: 76
Mileage: 27392 km
Time Indication: 0
Date: 2013.07.12
Time: 19:29:06
Freeze Frame:
RPM: 840 /min
Load: 29.0 %
Speed: 0.0 km/h
Temperature: 96.0°C
Temperature: 53.0°C
Absolute Pres.: 930.0 mbar
Voltage: 12.954 V
Desculpa pessoal, me enganei. Não é a mesma falha do @della, acabei fazendo confusão com algum outro tópico. Sorry :)
mfractal disse:
e a famosa HPFP meu amigo, 99% ctza!
Aconteceu 2 vezes ja...
segue um teste que voce pode fazer :
Special Functions
Checking Fuel Pressure
Prerequisites:
Ignition ON
Engine ON (Idle)
System voltage at least 11.0 V.
Coolant Temperature at least 80 °C
[Select]
[01 - Engine]
[Meas. Blocks - 08]
Group 103
[Go!]
Field 1: Fuel Pressure (Low), Specification: 2800...7200 mbar
Field 2: Fuel Pump Adaptation, Specification: -1000...+1000 %
Group 140
[Go!]
Field 3: Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Increase the Engine Speed while checking this value, the Pressure has to rise with the Engine Speed.
Group 230
[Go!]
Field 1: Specified Fuel Rail Pressure (High)
Field 2: Actual Fuel Rail Pressure (High), Specification: 25.0...110.0 bar
Field 3: Deviation between specified and actual fuel pressure, Specification: max. 5.0 bar
[Done, Go Back]
[Close Controller, Go Back - 06]
Sabe me dizer onde acho um tutorial pra calibrar a mecatrônica do câmbio? E já ouvi falar de um tutorial pra limpar o aviso de revisão no painel. Sabe onde encontro também? Obrigado!
