VAG - erros 8p 2008
Pessoal, hoje recebi o cabo Ross-Tech do @[member="mfractal"]. Excelente produto, recomendo comprarem.
instalei o CD, pluguei no carro e tal, show. fiz um scanner e apareceu varios erros. agora a luz do fela da puta do regulador de altura do farol aparece sempre.
quem tem pratica com esse programa e pode dar um help?
abaixo segue o log do programa.
e queria também habilitar luz de led na placa, luz de led na frente, e diminuir a sensibilidade do alarme, mas nào achei essas funções.
Tuesday,07,October,2014,17:14:32:65217
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUHF68P58A116819 License Plate: DVC9393
Mileage: 114490km-71140mi Repair Order:
Chassis Type: 8P (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 55 56 62 72 77
VIN: WAUHF68P58A116819 Mileage: 114490km/71140miles
01-Engine -- Status: Sporadic communication error 1000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0GNFNR123
Coding: 010310431C070160
Shop #: WSC 00191 264 15243
VCID: 438F574C026B1906C91-8016
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 050 J HW: 02E 927 770 AE
Component: GSG DSG 081 1401
Revision: 04708010 Serial number: 00000711150079
Coding: 0000020
Shop #: WSC 06314 000 00000
VCID: 1933D524D06773D673D-804C
1 Fault Found:
18258 - Powertrain Data Bus
P1850 - 000 - Missing Message from ECU - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 255
Reset counter: 7
Mileage: 113999 km
Time Indication: 0
Date: 2014.09.23
Time: 11:55:30
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021634
VCID: 73EFC78C124BE986991-8026
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0430
Revision: 222770 Serial number: 8P0820043AG
Shop #: WSC 00000 000 00000
VCID: 71E3CD846857DB966BD-8024
1 Fault Found:
01301 - Control Module for Voice Recognition (J507)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 174
Mileage: 107680 km
Time Indication: 0
Date: 2014.04.10
Time: 19:59:10
Freeze Frame:
ON
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007963979
Coding: E58E1F01901410004F1600001600000000085E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 458B49540C5F2736E75-8010
Subsystem 1 - Part No: 8P1 955 119 E Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 B Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0100
Coding: 00150573
Shop #: WSC 06314
3 Faults Found:
02401 - Terminal 75x
006 - Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00100110
Fault Priority: 2
Fault Frequency: 121
Reset counter: 0
Mileage: 113224 km
Time Indication: 0
Date: 2014.08.29
Time: 03:12:00
Freeze Frame:
OFF
Voltage: 12.50 V
ON
ON
OFF
OFF
OFF
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 113999 km
Time Indication: 0
Date: 2014.09.23
Time: 11:55:00
Freeze Frame:
ON
Voltage: 12.05 V
ON
ON
OFF
OFF
OFF
00975 - Heated Rear Window (Z1)
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 217
Mileage: 113878 km
Time Indication: 0
Date: 2014.09.17
Time: 13:00:00
Freeze Frame:
ON
Voltage: 13.70 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP001YRHX
Coding: 0071612
VCID: 4B9F7F6C2A3BD146311-801E
Subsystem 1 - Serial number: 6332DRB40670CB11L
Subsystem 2 - Serial number: 6342DRB406760826J
Subsystem 3 - Serial number: 63528RB40337B07EP
Subsystem 4 - Serial number: 63628RB4033718D0G
Subsystem 5 - Serial number: 63747RB4030A7FB5Y
Subsystem 6 - Serial number: 63847RB4030A7FC9/
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 41835D4418770B16DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0030
2 Faults Found:
01304 - Radio
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 J HW: 8P0 920 931 J
Component: KOMBIINSTR. VDO H22 0660
Revision: D0H22003 Serial number: 224NG003101410
Coding: 0000128
Shop #: WSC 04514 659 91253
VCID: 3A712AA875A158CE9A7-806F
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K07B290C13
Coding: ED817F060006022102
VCID: 30650880A3DD929E243-8065
2 Faults Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 176
Mileage: 113872 km
Time Indication: 0
Date: 2014.09.16
Time: 10:48:14
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 222
Mileage: 113999 km
Time Indication: 0
Date: 2014.09.23
Time: 11:55:30
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H22003 Serial number: AUX7Z0GNFNR123
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0050
Coding: 0000216
Address 44: Steering Assist
Cannot be reached
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H10 0080
Coding: 1880202002186D0985054C8FC677
VCID: 448D545007651E3EF0B-8011
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Subsystem 2 - Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
1 Fault Found:
01403 - Glass-Break Sensors; Rear
011 - Open Circuit - Intermittent
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000216
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3F875BBC6E837DE6AD9-806A
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 113560 km
Time Indication: 0
Date: 2014.09.04
Time: 10:19:28
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 40
Mileage: 113992 km
Time Indication: 0
Date: 2014.09.23
Time: 11:55:30
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
VCID: 428152481D71100EC27-8017
Address 77: Telephone Labels: None
VCID: 55AB9914BCFF97B6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
End ---------------------------------------------------------------------
Clique para responder para todos
Enviar
Membros VIP
Amigo, o bom eh você zerar os erros, e rodar com o carro para ver quais permanecem.
Tenta fazer isso e posta de novo, com ctza serão bem menos erros e a galera pode ajudar melhor.
Vou tentar
lembrando que o veículo é blindado, então vidros traseiros e desembaçador traseiro não conta. E o radio eu coloquei uma central multimidia. são 4 erros a menos hehe
vou hoje tentar zerar novamente e andar
Hoje aprendi a brincar melhor com o scanner.
zerei todos os erros, mas o maldito modulo de altura do xenon não apaga. ele apaga e volta, e isso não acontecia antes, e os farois sobem e descem automaticamente.
alguem tem alguma luz???
Tem que fazer o setting do xenon.
Uma vez fiz a merda de mexer ali e ficou dando esse erro, daí segui um procedimento do site da ross tech e resolvi, mas de cabeça não me lembro mais detalhes, dá uma pesquisada lá.
