Alessandrogon
Galera, pela segunda vez ao longo de uns 3 anos, depois de viajar bastante, perto de 4 horas, em dias bem quentes, meu A3 começou a cortar, perdendo força e não deixando o giro subir muito.
Na vez anterior, depois de esfriar totalmente, o carro ficou perfeito.
Dessa vez, hoje (12/10/2017), parei e passei o scanner. Quem tiver alguma ideia me fala, inclusive dos outros erros que aparecem aí.
Valeu!
VCDS Version: Release 11.11.4
Data version: 20120807
Thursday,12,October,2017,17:20:58:55062
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 76
77
VIN: WAUHF68PX8A022354 Mileage: 100050km/62168miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 8P0 907 115 T HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: AUX7Z0G5FNK0XW
Coding: 010310431C070160
Shop #: WSC 06314 000 00000
VCID: 438EF8660242CE007C7
8 Faults Found
001089 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 246
Mileage: 68589 km
Time Indication: 0
Date: 2015.09.16
Time: 08:47:48
Freeze Frame:
RPM: 767 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 69.0∞C
Temperature: 27.0∞C
Absolute Pres.: 920.0 mbar
Voltage: 13.970 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 002 - - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:01:53
Freeze Frame:
RPM: 770 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 40.0∞C
Temperature: 24.0∞C
Voltage: 14.224 V
000769 - Cylinder 1
P0301 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
000771 - Cylinder 3
P0303 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
000772 - Cylinder 4
P0304 - 002 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
012555 - Low Pressure Fuel regulation
P310B - 002 - Fuel Pressure Outside Specification - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 100037 km
Time Indication: 0
Date: 2017.10.12
Time: 15:34:30
Freeze Frame:
RPM: 1978 /min
Load: 23.1 %
Speed: 67.0 km/h
Temperature: 93.0∞C
Temperature: 43.0∞C
Absolute Pres.: 890.0 mbar
Voltage: 13.335 V
000135 - Fuel Rail/System Pressure
P0087 - 002 - Too Low - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100010
Fault Priority: 2
Fault Frequency: 15
Mileage: 100038 km
Time Indication: 0
Date: 2017.10.12
Time: 15:35:04
Freeze Frame:
RPM: 2562 /min
Load: 58.0 %
Speed: 68.0 km/h
Temperature: 93.0∞C
Temperature: 44.0∞C
Voltage: 13.462 V
008567 - Bank 1; System Too Lean off Idle
P2177 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 6
Mileage: 100040 km
Time Indication: 0
Date: 2017.10.12
Time: 15:37:34
Freeze Frame:
RPM: 1802 /min
Load: 22.0 %
Speed: 48.0 km/h
Temperature: 93.0∞C
Temperature: 42.0∞C
Absolute Pres.: 870.0 mbar
Voltage: 13.462 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 044 J HW: 02E 927 770 AE
Component: GSG DSG 081 1401
Revision: 04608010 Serial number: 00000705270122
Coding: 0000020
VCID: 1C3C631ADF7CD1F8DDD
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021634
VCID: 73EE68A612623E802C7
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 AG HW: 8P0 820 043 AG
Component: KlimavollautomatH19 0420
Revision: 154127 Serial number: 8P0820043AG
VCID: 71E262AE687E0C90DEB
1 Fault Found
00796 - Fan for Interior Temp Sensor (V42)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 3
Fault Frequency: 8
Reset counter: 46
Mileage: 98819 km
Time Indication: 0
Date: 2017.09.09
Time: 21:32:51
Freeze Frame:
Voltage: 11.90 V
Temperature: 15.5∞C
Address 09: Cent. Elect. Labels: 8P0-907-279-30-H.lbl
Part No SW: 8P0 907 279 K HW: 8P0 907 279 K
Component: Bordnetz-SG H54 2501
Revision: 00H54000 Serial number: 00000007228357
Coding: E58E1F0190141000471600001600000000085E175A050000000000000000
Shop #: WSC 06314 000 08192
VCID: 458AE67E0C76F030523
Subsystem 1 - Part No: 8P1 955 119 E
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 06314
Subsystem 2 - Part No: 4E0 910 557 A
Component: REGENLICHTSENSORH13 0090
Coding: 00150573
Shop #: WSC 06314
1 Fault Found
00987 - Lamp for Brake Light; Left (M9)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 1
Fault Frequency: 22
Reset counter: 46
Mileage: 97931 km
Time Indication: 0
Date: 2017.08.13
Time: 23:06:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 L HW: 8P0 959 655 L
Component: Airbag 9.41 H01 4210
Revision: 91H01421 Serial number: 003CP0G0DSJU
Coding: 0071612
VCID: 4B9ED0462A120640847
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0014142
VCID: 4182F26E185EDC106EB
Part No: XXXXXXXXXXX
Component: E0221 H02 0030
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 931 J HW: 8P0 920 931 J
Component: KOMBIINSTR. VDO H20 0640
Revision: D0H20001 Serial number: 2245G001001109
Coding: 0000128
Shop #: WSC 00011 888 96745
VCID: 3A70858275888FC82F1
1 Fault Found
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Mileage: 68570 km
Time Indication: 0
Date: 2015.09.14
Time: 10:14:48
Address 19: CAN Gateway Labels: Redir Fail!
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533__Gateway H15 0180
Revision: H15 Serial number: 1400K0761584B7
Coding: ED817F0E1006022102
VCID: 3064A7AAA3F44598915
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H20001 Serial number: AUX7Z0G5FNK0XW
Shop #: WSC 00152 659 91253
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 K HW: 8P0 959 801 K
Component: Tuer-SG H03 0040
Coding: 0000216
2 Faults Found
01552 - Motor for Central Locking; Drivers Door (V56); Lock
00928 - Locking Module for Central Locking; Front Driver Side (F220)
008 - Implausible Signal - Intermittent
Address 44: Steering Assist Labels: Redir Fail!
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.079 H08 1901
Shop #: WSC 02069 000 90108
VCID: 356A96BE5C9660B0C23
Address 46: Central Conv. Labels: 8P0-959-433.lbl
Part No: 8P0 959 433 K
Component: KSG H10 0080
Coding: 1880202002586D09850D4CCFC677
VCID: 448CFB7A074CC93845D
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 907 719 C
Component: Neigungssensor 005 0003
Part No: 8P0 951 177
Component: Innenraumueberw.H04 0020
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 D HW: 8P4 035 382 D
Component: AB2 SUBWOOFERBOXH06 0180
Revision: 00005 Serial number: 30674703017552
Shop #: WSC 00000 000 00000
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 8P0 959 802 K HW: 8P0 959 802 K
Coding: 0000216
1 Fault Found
00929 - Locking Module for Central Locking; Front Passenger Side (F221)
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 F
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000012
VCID: 3D7A8E9E64A6B8F00A3
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 E HW: 8P4 959 801 E
Component: Tuer-SG H04 0040
Coding: 0000216
Shop #: WSC 06314 000 1012544
1 Fault Found
00930 - Locking Module for Central Locking; Rear Left (F222)
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 E HW: 8P4 959 802 E
Coding: 0000216
Shop #: WSC 06314 000 1012557
VCID: 4280FD621D58C708771
Address 76: Park Assist Labels: 8P0-919-283.lbl
Part No SW: 8P0 919 283 D HW: 8P0 919 283 D
Component: Parkhilfe 4-Kan H09 0070
Revision: 00H09000 Serial number: 00067824830716
Coding: 0001013
Shop #: WSC 131071 1023 2097151
VCID: 3C7C839A7FBCB1F83DD
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 K HW: 8P0 862 335 K
Component: FSE_255x BT H26 0340
Revision: 00000000 Serial number: 00000005205056
Coding: 0001225
VCID: 3E78899269A0A3E8139
End ---------------------------------------------------------------------
Valeu!
Chassis Type: 1K0
77
8 Faults Found
Freeze Frame:
Fault Priority: 2
Mileage: 68589 km
Time Indication: 0
Date: 2015.09.16
Time: 08:47:48
Freeze Frame:
RPM: 767 /min
Load: 16.9 %
Speed: 0.0 km/h
Temperature: 69.0∞C
Temperature: 27.0∞C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:01:53
Freeze Frame:
RPM: 770 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 40.0∞C
Temperature: 24.0∞C
Voltage: 14.224 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
000771 - Cylinder 3
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Mileage: 99225 km
Time Indication: 0
Date: 2017.09.25
Time: 14:02:19
Freeze Frame:
RPM: 846 /min
Load: 21.6 %
Speed: 0.0 km/h
Temperature: 41.0∞C
Temperature: 24.0∞C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 100037 km
Time Indication: 0
Date: 2017.10.12
Time: 15:34:30
Freeze Frame:
RPM: 1978 /min
Load: 23.1 %
Speed: 67.0 km/h
Temperature: 93.0∞C
Temperature: 43.0∞C
Voltage: 13.335 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 15
Mileage: 100038 km
Time Indication: 0
Date: 2017.10.12
Time: 15:35:04
Freeze Frame:
RPM: 2562 /min
Load: 58.0 %
Speed: 68.0 km/h
Temperature: 93.0∞C
Temperature: 44.0∞C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 6
Mileage: 100040 km
Time Indication: 0
Date: 2017.10.12
Time: 15:37:34
Freeze Frame:
RPM: 1802 /min
Load: 22.0 %
Speed: 48.0 km/h
Temperature: 93.0∞C
Temperature: 42.0∞C
Voltage: 13.462 V
Coding: 0000020
Revision: 00H11001
Coding: 0021634
1 Fault Found
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 46
Mileage: 98819 km
Time Indication: 0
Date: 2017.09.09
Time: 21:32:51
Freeze Frame:
Voltage: 11.90 V
Temperature: 15.5∞C
Coding: 00062736
Shop #: WSC 06314
Coding: 00150573
Shop #: WSC 06314
1 Fault Found
Freeze Frame:
Fault Priority: 1
Fault Frequency: 22
Reset counter: 46
Mileage: 97931 km
Time Indication: 0
Date: 2017.08.13
Time: 23:06:00
Freeze Frame:
ON
Voltage: 13.80 V
ON
ON
OFF
OFF
OFF
Coding: 0071612
Coding: 0014142
Coding: 0000128
1 Fault Found
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Mileage: 68570 km
Time Indication: 0
Date: 2015.09.14
Time: 10:14:48
Coding: 0000216
2 Faults Found
Coding: 0000216
1 Fault Found
Coding: 0000012
Address 56: Radio
Cannot be reached
Coding: 0000216
1 Fault Found
Coding: 0000216
Coding: 0001013
Coding: 0001225
