pati520bii
Technical data
Model rotary heat transfer press
Maximum Media Width 1.2 M
Diameter of Drum 420 mm
Temperature Range 0-399 ℃
Time Range 0-999 S
Working Table Including working table
Fed-in media Transfer paper,fabric,protective paper
Feeding Method Top Feeding
Voltage / Heating Power 220/380 Three phase four wire
Packing Dimension 215x145x174cm
Gross Weight 1000kg
Warranty 1 Year
Feature
1. Integrated the operating panel
2. Automatic cooling and shut down
3. Anti-explosion device
4. Automatic fabric ,sublimation paper and craft paper feed and collect device
5. Safety Unit Prevent hand and scissors be drawn into drum
6. Blanket can separate from drum automatic and manual totally
7. Automatic conveyor belt centering system
8. Air shaft for paper feeding smooth
9. Double side emergency button
10. DuPont material blanket
11. Chrome Drum
12. 100% full fill oil thermal drum
13. Additional pneumatic pressure
14. Teflon mesh conveyor for cooling quickly
FAQ
1. How wide is the machine?
1.2M width
2. How about the speed ?
150-300m/h, depend on the fabric and the transfer speed.
3. Are you able to print on dark Fabrics? if so how dark and on what contents? Can it print on stretch goods?
This press machine can press light color fabric,not dark fabric but can print on stretch fabric
4. Do you supply Paper and ink and Parts?
We also offer paper and ink.
5. Do you have representatives in USA ?
We have representatives in USA Rotary Heat Transfer Machine manufacturers
website:http://www.jcheatpress.com/rotary-heat-transfer-machine/
Time Range 0-999 S
Gross Weight 1000kg
Warranty 1 Year
Feature
11. Chrome Drum
FAQ
1.2M width
