alvaresmoura
Boa noite galera,
Preciso de uma ajudinha com um scan feito com o vagcom.
Meu carro começou a alarmar problemas com o nivel do oleo no painel, e ao verificar o nivel, o mesmo está no maximo, dai passei o vag e tive o seguinte resultado:
Address 01: Engine (MSTR-CDNB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 Q HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0003
Revision: E1H14---
Coding: 0104100C02070160
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_ECM20TFS8K2907115Q A01005
ROD: EV_ECM20TFS0118K2907115AH.rod
VCID: 3D71DF7FAC8475F6BF5-8068
3 Faults Found:
5580 - Oil Pressure Switch
P164B 00 [032] - Malfunction
Intermittent - Not Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 92863 km
Date: 2015.02.22
Time: 09:57:01
5582 - Oil Pressure Switch for reduced Oil Pressure
P164D 00 [032] - Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 92854 km
Date: 2015.02.22
Time: 08:26:56
4113 - Camshaft Position Sensor (G40)
P0341 00 [096] - Implausible Signal
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Mileage: 92856 km
Date: 2015.02.22
Time: 09:45:48
Readiness: 0000 0000
Sabem dizer se isso problema em algum sensor ou na bomba de oleo?
Desde ja agradeço!
Revision: E1H14---
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 92863 km
Date: 2015.02.22
Time: 09:57:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 92854 km
Date: 2015.02.22
Time: 08:26:56
Freeze Frame:
Fault Priority: 2
Fault Frequency: 61
Mileage: 92856 km
Date: 2015.02.22
Time: 09:45:48
Desde ja agradeço!
