williansilvano
passei o vag pela primeira vez no carro e pela primeira vez Eu o usei tambem
o procedimento foi o seguinte:
Passei no Auto Scan ( limpei os erros e passei novamente ) , e deu um monte de errro pra minha tristeza
Se alguem poder me dar um força pra ver o que pode ser esses erros...
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,17,22,35,37,45,54,55,56
Address 01 -------------------------------------------------------
Controller: 032 906 032 G
Component: ME7.5.10 3800
Coding: 00011
Shop #: WSC 00000
93UMA28L844004354 AUZ7Z0C2515028
1 Fault Found:
17987 - Throttle Actuator (J338): Adaptation Not Started
P1579 - 35-10 - - - Intermittent
Readiness: 0000 0100
Address 03 -------------------------------------------------------
Controller: 1C0 907 379 L
Component: ABS FRONT MK60 0101
Coding: 0004097
Shop #: WSC 00000
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
Address 08 -------------------------------------------------------
Controller: 8L0 820 043 H
Component: A3 KLIMAAUT
Note: Excessive Comm Errors
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 8L0 920 901 A
Component: KOMBI+WEGFAHRS. VDO D10
Coding: 02544
Shop #: WSC 02544
1 Fault Found:
01336 - Data Bus for Comfort System
37-00 - Faulty
Address 35 -------------------------------------------------------
Controller: 8L0 862 257 G
Coding: 13422
Shop #: WSC 00146
1 Fault Found:
01361 - Switch for Anti-Theft Alarm: Close
29-00 - Short to Ground
Address 45 -------------------------------------------------------
Controller: 4B0 951 173
Coding: 00001
Shop #: WSC 00000
No fault code found.
End -------------------------------------------------------
Coding: 00011
Shop #: WSC 00000
1 Fault Found:
Coding: 0004097
Shop #: WSC 00000
No Faults Found
Coding: 02544
Shop #: WSC 02544
1 Fault Found:
37-00 - Faulty
Coding: 13422
Shop #: WSC 00146
1 Fault Found:
Coding: 00001
Shop #: WSC 00000
