leandrinho
passei o scan no carro hoje mais como estou com o carro a 3 semanas e o software rossi ainda nao manjo nada pessoa ajuda ..
Wednesday,01,April,2015,15:09:06:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUAFK8P3BA019183 License Plate: SCAN1
Mileage: 45350km-28179mi Repair Order:
Chassis Type: 8P (8P0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 3D 42 44 46 47 52 55 56 62
72 77
VIN: WAUAFK8P3BA019183 Mileage: 45350km/28179miles
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
3D-Special Function -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
56-Radio -- Status: Cannot be reached 1100
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: Malfunction 0010
Address 01: Engine (CCZ) Labels: 06J-907-115-CCZ.clb
Part No SW: 8P0 907 115 BA HW: 8P0 907 115 Q
Component: 2.0l R4/4V TFSI 0010
Revision: AAH17--- Serial number: AUX7Z0J5FNS0BG
Coding: 0103100C1C070160
Shop #: WSC 06314 000 00000
VCID: 72EB3C436D5AFA8E927-8027
5 Faults Found:
053271 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 - 015 -
Freeze Frame:
Fault Status: 01101111
Fault Priority: 0
Fault Frequency: 145
Reset counter: 255
Mileage: 44771 km
Time Indication: 0
Date: 2015.02.02
Time: 20:13:14
Freeze Frame:
RPM: 1036 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 60.0°C
Absolute Pres.: 920.0 mbar
Voltage: 11.684 V
U1017 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 16
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 23.0°C
Absolute Pres.: 930.0 mbar
Voltage: 11.811 V
U1017 - 007 - - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 0
Fault Frequency: 26
Reset counter: 255
Mileage: 45356 km
Time Indication: 0
Date: 2015.03.29
Time: 01:34:34
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 48.0°C
Voltage: 12.319 V
005386 - Engine Off Timer Performance
P150A - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 45.0°C
Temperature: 25.0°C
Voltage: 12.192 V
001089 - EVAP Emission Control Sys
P0441 - 000 - Incorrect Flow - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 45143 km
Time Indication: 0
Date: 2015.03.24
Time: 04:46:17
Freeze Frame:
RPM: 756 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 101.0°C
Temperature: 45.0°C
Voltage: 13.208 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 053 N HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2209
Revision: 05151112 Serial number: 00001006120085
Coding: 0000020
VCID: 204F060BF336381EB43-8075
No fault code found.
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AT HW: 1K0 907 379 AT
Component: ESP MK60EC1 H30 0105
Revision: 00H30001
Coding: 144260120A230003280C06EC501C0041390800
VCID: 8407EA9B07EE443E30B-80D1
4 Faults Found:
00287 - ABS Wheel Speed Sensor; Rear Right (G44)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 1
Fault Frequency: 1
Reset counter: 86
Mileage: 45023 km
Time Indication: 0
Date: 2015.03.16
Time: 03:10:19
Freeze Frame:
Count: 1088
Count: 0
Count: 4608
Count: 89
Count: 48128
Count: 0
Count: 0
Count: 0
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 1
Fault Frequency: 30
Reset counter: 102
Mileage: 44829 km
Time Indication: 0
Date: 2015.02.18
Time: 00:57:26
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 83
Count: 50689
Count: 65024
Count: 0
Count: 0
03842 - RPM Sensor Rear Right: Incorrect Signal
000 - - - Intermittent
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 70
Mileage: 44829 km
Time Indication: 0
Date: 2015.02.18
Time: 00:50:20
Freeze Frame:
Count: 0
Count: 14
Count: 12288
Count: 87
Count: 43264
Count: 256
Count: 255
Count: 0
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 1
Fault Frequency: 36
Reset counter: 71
Mileage: 44765 km
Time Indication: 0
Date: 2015.02.02
Time: 19:06:30
Freeze Frame:
Count: 16384
Count: 14
Count: 12800
Count: 80
Count: 50176
Count: 512
Count: 255
Count: 9472
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000026 Serial number: 8P0820043BM
Shop #: WSC 00000 000 00000
VCID: 78FF0E6B0B2690DEAC3-802D
2 Faults Found:
00601 - Potentiometer On Positioning Motor for Central Flap (G112)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:13:41
Freeze Frame:
Voltage: 11.70 V
(no units): 255.0
Temperature: 19.5°C
01177 - Engine Control Unit
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 7
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
ON
Address 09: Cent. Elect. (J519) Labels: 8P0-907-063.clb
Part No SW: 8P0 907 063 K HW: 8P0 907 063 K
Component: BCM PQ35 M 107 0615
Revision: 00107 AF
Coding: 0E000A2FB00FF0C0207241E02100095CC37E2BAAB16DD929E40000840040
Shop #: WSC 00152 659 999999
VCID: 3C77D27BBF9E7CFE88B-8069
Subsystem 1 - Part No SW: 8P1 955 119 F HW: 8P1 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 4 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H05 1501
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
10 Faults Found:
00061 - Footwell Lights
Freeze Frame:
Fault Status: 01101010
Fault Priority: 5
Fault Frequency: 118
Reset counter: 71
Mileage: 44802 km
Time Indication: 0
Date: 2015.02.12
Time: 15:31:20
Freeze Frame:
Term 15 Off
Voltage: 9.50 V
OFF
ON
Term 50 Off
OFF
OFF
02195 - Dimmer Switch Instrument Panel & Switch Lighting (E20)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.22
Time: 23:37:00
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
01800 - Light Switch (E1)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01314 - Engine Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
01316 - ABS Control Module
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
01309 - Power Steering Control Module (J500)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:03
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
02391 - Terminal 30 Reference
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 4
Fault Frequency: 1
Reset counter: 100
Mileage: 45144 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
Address 10: Park/Steer Assist (J791) Labels: Redir Fail!
Part No SW: 8P0 919 475 K HW: 8P0 919 475 B
Component: PARKHILFE PLA H07 0120
Revision: 11001001 Serial number: 84841015601569
Coding: 000103
VCID: 4683B093F152362EEEF-8013
6 Faults Found:
01312 - Powertrain Data Bus
Freeze Frame:
Fault Priority: 6
Fault Frequency: 254
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
Freeze Frame:
Temperature: 19.0°C
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 6
Fault Frequency: 197
Reset counter: 111
Mileage: 44765 km
Time Indication: 0
Date: 2015.02.02
Time: 19:06:30
Freeze Frame:
Temperature: 26.0°C
00466 - Control Module for Steering Column Electronics (J527)
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Address 15: Airbags (J234) Labels: 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H07 0200
Revision: -------- Serial number: 003FB007TAE3
Coding: 30314238303830303131554A304C38503053
ASAM Dataset: EV_Airba10AURB4 001001
ROD: EV_Airba10AURB4.rod
VCID: 4FAD95B71628F7665D9-801A
Crash sensor for side airbag; driver side:
Serial number: 3572DRB40000BABCC302
Crash sensor for side airbag; passenger side:
Serial number: 3582DRB40000BABCC336
Crash sensor for side airbag; rear driver side:
Serial number: 35128RB400005A107479
Crash sensor for side airbag; rear passenger side:
Serial number: 35228RB400005A1066AE
Crash sensor for front airbag; driver side:
Serial number: 35547RB400005A360B9O
Crash sensor for front airbag; passenger side:
Serial number: 35647RB400005A360A0F
5 Faults Found:
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [136] - Open or Short to Plus
MIL ON - Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 2
Mileage: 40783 km
Date: 2014.07.20
Time: 20:07:42
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [136] - Open or Short to Plus
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 40783 km
Date: 2014.07.20
Time: 20:07:41
12670208 - No Communication with Instrument Cluster
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 111
13636864 - Control Module for ABS Brakes
U1015 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Fault Frequency: 102
Reset counter: 111
12583424 - Powertrain Databus
U0002 00 [008] - No Communications
Freeze Frame:
Fault Priority: 6
Mileage: 30506 km
Date: 2014.04.09
Time: 00:00:13
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0014142
VCID: 4683B0933152362EEEF-8013
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
2 Faults Found:
01304 - Radio
00002 - Transmission Control Unit
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 932 K HW: 8P0 920 932 K
Component: KOMBIINSTR. VDO H01 0090
Revision: D0H01003 Serial number: 2245J003009244
Coding: 0384128
Shop #: WSC 00152 659 91253
VCID: 3C77D27B7F9E7CFE88B-8069
Address 19: CAN Gateway Labels: 7N0-907-530-V1.clb
Part No SW: 8P0 907 530 HW: 1K0 907 951
Component: J533 Gateway H32 0302
Revision: H32 Serial number: 180610F1001090
Coding: EDA17F0611060200002102
VCID: F0EFB64BE356489EE43-80A5
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Status: 01100100
Fault Priority: 2
Fault Frequency: 2
Reset counter: 162
Mileage: 37347 km
Time Indication: 0
Date: 2014.05.27
Time: 20:36:32
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Revision: D0H01003 Serial number: AUX7Z0J5FNS0BG
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 A HW: 8K0 907 440
Component: STS H04 0030
Revision: S0H04000 Serial number: 00000000019477
Coding: 01010101000000000000000102
VCID: 2C57E23B8FFEEC7E18B-8079
1 Fault Found:
03420 - Activation of Accelerator Pedal Position Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 111
Mileage: 45132 km
Time Indication: 0
Date: 2015.03.23
Time: 06:07:48
Address 42: Door Elect, Driver Labels: 8P0-959-801-MIN3.lbl
Part No SW: 8P0 959 801 Q HW: 8P0 959 801 Q
Component: Tuer-SG H04 0101
Coding: 0000220
VCID: 4999BBAF204CD95603D-801C
Address 44: Steering Assist Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 E HW: 8P4 035 382 E
Component: AB2 SUBWOOFERBOXH07 0180
Revision: 00006 Serial number: 92158068333729
VCID: 3663C05341B2A6AE7EF-8063
Address 52: Door Elect, Pass. Labels: None
Part No SW: 8P5 959 802 T HW: 8U0 959 807 Q
Component: Tuer(SG % H01 0101
Shop #: WSC 71850 002 00000
VCID: 52AB9CC3CD1A9A8E727-8007
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P3 907 357 B
Component: Dynamische LWR H01 0010
Revision: 00000001 Serial number:
Coding: 0000013
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 71
Mileage: 45128 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 71
Mileage: 45128 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
01317 - Control Module in Instrument Cluster (J285)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 45352 km
Time Indication: 0
Date: 2015.03.30
Time: 23:33:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 45352 km
Time Indication: 0
Date: 2015.03.31
Time: 04:05:00
Address 56: Radio
Cannot be reached
Address 62: Door, Rear Left Labels: 8P4-959-801.lbl
Part No SW: 8P4 959 801 F HW: 8P4 959 801 F
Component: Tuer-SG H04 0050
Coding: 0000216
Shop #: WSC 06314 000 1012544
VCID: 428BAC831D7A0A0EC27-8017
Address 72: Door, Rear Right Labels: 8P4-959-802.lbl
Part No SW: 8P4 959 802 F HW: 8P4 959 802 F
Coding: 0000216
VCID: 4385A98702600306C91-8016
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P1 862 335 HW: 8P1 862 335
Component: FSE_256x BT H41 0650
Revision: 00000000 Serial number: 00000005313563
Coding: 0001255
VCID: F4E7BA5B974E74BE00B-80A1
2 Faults Found:
02503 - Output Wire to Radio
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 1
Reset counter: 162
Mileage: 38057 km
Time Indication: 0
Date: 2014.07.06
Time: 22:58:02
01304 - Radio
Freeze Frame:
Fault Priority: 6
Reset counter: 71
Mileage: 37347 km
Time Indication: 0
Date: 2014.05.27
Time: 21:08:50
End ---------------------------------------------------------------------
72 77
5 Faults Found:
U1017 - 015 -
Freeze Frame:
Fault Priority: 0
Reset counter: 255
Mileage: 44771 km
Time Indication: 0
Date: 2015.02.02
Time: 20:13:14
Freeze Frame:
RPM: 1036 /min
Load: 14.5 %
Speed: 0.0 km/h
Temperature: 91.0°C
Temperature: 60.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 16
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 20.0°C
Temperature: 23.0°C
Voltage: 11.811 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 26
Reset counter: 255
Mileage: 45356 km
Time Indication: 0
Date: 2015.03.29
Time: 01:34:34
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 55.0°C
Temperature: 48.0°C
Voltage: 12.319 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Time Indication: 0
Date: 2047.15.31
Time: 31:63:63
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 45.0°C
Temperature: 25.0°C
Voltage: 12.192 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 45143 km
Time Indication: 0
Date: 2015.03.24
Time: 04:46:17
Freeze Frame:
RPM: 756 /min
Load: 17.2 %
Speed: 0.0 km/h
Temperature: 45.0°C
Voltage: 13.208 V
Coding: 0000020
Revision: 00H30001
4 Faults Found:
Freeze Frame:
Fault Priority: 1
Fault Frequency: 1
Reset counter: 86
Mileage: 45023 km
Time Indication: 0
Date: 2015.03.16
Time: 03:10:19
Freeze Frame:
Count: 1088
Count: 0
Count: 4608
Count: 89
Count: 48128
Count: 0
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 30
Reset counter: 102
Mileage: 44829 km
Time Indication: 0
Date: 2015.02.18
Time: 00:57:26
Freeze Frame:
Count: 0
Count: 0
Count: 4608
Count: 83
Count: 50689
Count: 65024
Count: 0
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 11
Reset counter: 70
Mileage: 44829 km
Time Indication: 0
Date: 2015.02.18
Time: 00:50:20
Freeze Frame:
Count: 0
Count: 14
Count: 12288
Count: 87
Count: 43264
Count: 256
Count: 255
Count: 0
Freeze Frame:
Fault Priority: 1
Fault Frequency: 36
Reset counter: 71
Mileage: 44765 km
Time Indication: 0
Date: 2015.02.02
Time: 19:06:30
Freeze Frame:
Count: 16384
Count: 14
Count: 12800
Count: 80
Count: 50176
Count: 512
Count: 255
Count: 9472
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:13:41
Freeze Frame:
Voltage: 11.70 V
(no units): 255.0
Temperature: 19.5°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
ON
Revision: 00107 AF
Coding: 00DD13
Coding: 024C2D
10 Faults Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 71
Mileage: 44802 km
Time Indication: 0
Date: 2015.02.12
Time: 15:31:20
Freeze Frame:
Term 15 Off
Voltage: 9.50 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.22
Time: 23:37:00
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 45121 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
Term 15 Off
Voltage: 12.30 V
OFF
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 12.00 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 11
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:02
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 6
Fault Frequency: 10
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:03
Freeze Frame:
Term 15 On
Voltage: 11.95 V
ON
ON
Term 50 Off
OFF
OFF
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 100
Mileage: 45144 km
Time Indication: 0
Date: 2000.00.00
Time: 31:63:63
Freeze Frame:
Term 15 Off
Voltage: 12.45 V
OFF
ON
Term 50 Off
OFF
OFF
Coding: 000103
6 Faults Found:
Freeze Frame:
Fault Priority: 6
Reset counter: 111
Mileage: 45121 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 12
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 17
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
Freeze Frame:
Fault Priority: 6
Reset counter: 111
Mileage: 44765 km
Time Indication: 0
Date: 2015.02.02
Time: 19:06:30
Freeze Frame:
Temperature: 26.0°C
Freeze Frame:
Fault Priority: 6
Fault Frequency: 22
Reset counter: 111
Time Indication: 0
Freeze Frame:
Temperature: 19.0°C
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 40783 km
Date: 2014.07.20
Time: 20:07:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Mileage: 40783 km
Date: 2014.07.20
Time: 20:07:41
U0155 00 [008] - -
Freeze Frame:
Fault Priority: 6
Fault Frequency: 7
Reset counter: 111
Freeze Frame:
Fault Priority: 6
Reset counter: 111
Freeze Frame:
Fault Priority: 6
Mileage: 30506 km
Date: 2014.04.09
Time: 00:00:13
Coding: 0014142
2 Faults Found:
01304 - Radio
Coding: 0384128
1 Fault Found:
01304 - Radio
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 162
Mileage: 37347 km
Time Indication: 0
Date: 2014.05.27
Time: 20:36:32
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 111
Mileage: 45132 km
Time Indication: 0
Date: 2015.03.23
Time: 06:07:48
Coding: 0000220
No Faults Found
Coding: 0000013
5 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 10
Reset counter: 71
Mileage: 45128 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 111
Time Indication: 0
Freeze Frame:
Fault Priority: 2
Fault Frequency: 11
Reset counter: 71
Mileage: 45128 km
Time Indication: 0
Date: 2015.03.23
Time: 00:20:01
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 71
Mileage: 45352 km
Time Indication: 0
Date: 2015.03.30
Time: 23:33:37
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 111
Mileage: 45352 km
Time Indication: 0
Date: 2015.03.31
Time: 04:05:00
Address 56: Radio
Cannot be reached
Coding: 0000216
Coding: 0000216
Coding: 0001255
2 Faults Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 162
Mileage: 38057 km
Time Indication: 0
Date: 2014.07.06
Time: 22:58:02
01304 - Radio
Freeze Frame:
Fault Priority: 6
Reset counter: 71
Mileage: 37347 km
Time Indication: 0
Date: 2014.05.27
Time: 21:08:50
