[Ajuda] Relatorio do VAG-COM
Boa tarde galera, passei o scanner no carro, A3 1.8T 150cv AT, e gostaria de saber quais os procedimentos que devo realizar para corrigir os erros abaixo. Em relacao ao 00561 eu possuo um vazamento na mangueira do hidrovacuo 1J0612041ES isso teria alguma relacao com o problema em questao?
Código:
Friday,03,February,2017,19:50:49:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
Mileage: 106800km-66362mi   Repair Order:
Chassis Type: XX (8L - Audi A3/S3 (1997 > 2003))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: XXXXXXXXXXXXXXXXX   Mileage: 106800km/66362miles
Address 01: Engine        Labels: 06A-906-018-AGU.lbl
   Part No: 06A 906 018 CJ
   Component: 1.8L R4/5VT MOTR AT D01
   Coding: 04030
   Shop #: WSC 00001
   VCID: 6CD1B2EB1C09257E575-49D8
3 Faults Found:
00561 - Mixture Adaptation
            13-00 - Adaptation Limit (Mul) Not Reached
            14-00 - Adaptation Limit (Add) Exceeded
16514 - Oxygen (Lambda) Sensor B1 S1
            P0130 - 35-10 - Malfunction in Circuit - Intermittent
Readiness: N/A
Address 02: Auto Trans        Labels: 01M-927-733.lbl
   Part No: 01M 927 733 LC
   Component: AG4 Getriebe 01M    4967
   Coding: 00000
   Shop #: WSC 00000
   VCID: 7CF182AB6C69B5FEC75-0960
No fault code found.
Address 03: ABS Brakes        Labels: 1C0-907-37x-ABS.lbl
   Part No: 1C0 907 379 L
   Component: ABS FRONT MK60      0101
   Coding: 0004097
   Shop #: WSC 00001 785 00200
   VCID: 3363699751B7BA8656F-5000
Address 08: Auto HVAC        Labels: Redir Fail!
   Part No: 8L0 820 043 K
   Component: A3  KLIMAAUTOMAT   0105
   Coding: 00040
   Shop #: WSC 00001
   VCID: 3069669BF0A1819E2BD-254E
Address 15: Airbags        Labels: 8L0-959-655-AI8.lbl
   Part No: 8L0 959 655 L
   Component: Airbag Front+Seite 7008
   Coding: 00104
   Shop #: WSC 00001
   VCID: 479B2D47652F26261A7-5000
Address 17: Instruments        Labels: 8L0-920-xxx-17.lbl
   Part No: 8L0 920 932 M
   Component: KOMBI+WEGFAHRS. VDO D10
   Coding: 00544
   Shop #: WSC 04512
   VCID: 3A7D44B326DD4BCE959-5072
   XXXXXXXXXXXXXXXXX     AUZ7Z0B2181776
Address 35: Centr. Locks        Labels: 8D0-862-257.lbl
   Part No: 8L0 862 257 G
   Coding: 13166
   Shop #: WSC 00001
   VCID: 397F5BBF23DB40D69C3-4DD6
5 Faults Found:
            35-00 - -
01370 - Alarm triggered by Interior Monitoring
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01389 - Tailgate Open Switch (F124)
            29-00 - Short to Ground
00955 - Key 1
Address 45: Inter. Monitor        Labels: 4B0-951-173.lbl
   Part No: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00001
   Shop #: WSC 00001
   VCID: E0C956DB60C1F11E7BD-4A9C
Address 56: Radio        Labels: None
   Part No: 8L0 035 195 J
   Component: symphony II NP2    0050
   Coding: 05001
   Shop #: WSC 00001
   VCID: 3567578F0FC3A4B678B-4DD6
End   ---------------------------------------------------------------------
