Olá pessoal...
umas 2 vezes por mes eu passo o vag.
hoje apareceram esses 3 erros. o carro nao apresenta nenhum problema. a nao ser o erro que da no cambio (CNZ) quando passo pra posição manual, ela continua igual. em D. no painel tambem nao muda pra 1,2,3,4,5. fica igual PRND....
alguem sabe como posso começar?
olhem os codigos.
1:
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms:
- Malfunction Indicator Light (MIL) ON
Possible Causes:
- Fuel Pump Relay (J17) faulty
- Hoses/Pipes to/between Components faulty/clogged
- Secondary Air Injection Pump (V101) faulty
- Secondary Air Injection Pump Relay (J299) faulty
- Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions:
- Check Fuel Pump Relay (J17)
- Check Hoses/Pipes to/between Components
- Check Secondary Air Injection Hoses/Pipes for Carbonization
- Check Secondary Air Injection Pump (V101)
- Check Secondary Air Injection Pump Relay (J299)
- Check Secondary Air Injection Solenoid Valve (N112)
2:
17511/P0411/001041 - Oxygen (Lambda) Sensor Heating; B1 S1: Performance too Low
Possible Solutions:
- Check Oxygen Sensor Heating for Oxygen Sensor before Catalytic Converter
e o do tip
3:
01045 - Tiptronic Switch (F189): Implausible Signal
Possible Symptoms:
- Gear position (PRINDLE) positions on dash are all illuminated
- Transmission will not shift manually when slid into the +/- selection
Possible Causes:
- Wiring problem
- Tiptronic switch F189 faulty
- Tiptronic magnet housing alignment problem
Possible Solutions:
- Check wiring and connections according as per wiring diagram(s)
- Check Tiptronic Recognition Measuring Blocks. (MB 012 on 09G trans)
- Check Tiptronic switch F189
bom, como eu falei, o carro nao apresenta nada. só as vezes esse problema do tip, que é intermitente...quando aparece eu desligo o carro ligo de novo e volta a funcionar....
os mais experientes no vag me ajudem por gentileza.
abraço!
olhem os codigos.
1:
Possible Symptoms:
Possible Causes:
Possible Solutions:
2:
Possible Solutions:
e o do tip
3:
Possible Symptoms:
Possible Causes:
- Wiring problem
Possible Solutions:
abraço!
