Intaum galera,passei o cabo no meu carro ui...
um a3 180 mt 06
olha noque deu :/
VAG-COM Version: Release 704.1
Data version: 20070422
Monday,21,March,2011,00:16:10:59303
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: XXXXXXXXXXXXXXXXX Mileage: 103970km/64603miles
Address 01: Engine Labels: 06A-906-032-AJQ.LBL
Part No: 06A 906 032 S
Component: 1.8L R4/5VT G 0004
Coding: 05500
Shop #: WSC 00000
2 Faults Found:
16518 - Oxygen (Lambda) Sensor B1 S1: No Activity
P0134 - 35-10 - - - Intermittent
17524 - Oxygen (Lambda) Sensor Heating; B1 S1: Open Circuit
P1116 - 35-00 - -
Readiness: 0000 0000
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.LBL
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00000
No fault code found.
Address 08: Auto HVAC Labels: None
Part No: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00040
Shop #: WSC 00000
Address 15: Airbags Labels: None
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 9008
Coding: 00104
Shop #: WSC 00000
Address 17: Instruments Labels: 8L0-920-xxx-17.LBL
Part No: 8L0 920 933 T
Component: KOMBI+WEGFAHRS. VDO D17
Coding: 02544
Shop #: WSC 00155
XXXXXXXXXXXXXXXXX AUZ7Z0E2753648
Address 35: Centr. Locks Labels: 8L0-862-257-G.LBL
Part No: 8L0 862 257 G
Coding: 14220
Shop #: WSC 00064
7 Faults Found:
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01361 - Switch for Anti-Theft Alarm; Close
29-00 - Short to Ground
00956 - Key 2
Address 45: Inter. Monitor Labels: 4B0-951-173.LBL
Part No: 4B0 951 173
Coding: 00001
Shop #: WSC 00000
Address 56: Radio Labels: None
Part No: 8L0 035 195 N
Component: symphony II PM6 0470
Coding: 00017
Shop #: WSC 98000
4 Faults Found:
01300 - Control Module for Navigation with CD-Rom (J401)
49-00 - No Communications
00466 - Control Module for Steering Column Electronics (J527)
00856 - Radio Antenna
36-00 - Open Circuit
00858 - Connection; Radio ZF Output to Antenna Amplifier
End --------------------------------------------------------------------------------------------------
um a3 180 mt 06
olha noque deu :/
Coding: 05500
Shop #: WSC 00000
2 Faults Found:
P1116 - 35-00 - -
Coding: 0018945
Shop #: WSC 00000
Coding: 00040
Shop #: WSC 00000
Coding: 00104
Shop #: WSC 00000
Coding: 02544
Shop #: WSC 00155
Coding: 14220
Shop #: WSC 00064
7 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00001
Shop #: WSC 00000
Coding: 00017
Shop #: WSC 98000
4 Faults Found:
