alvaresmoura
Boa noite senhores,
Comprei o cabo vagcom e passei no meu carro onde gerou o relatorio abaixo listado, porem nao consigo descobrir o que essas falhas significam...
Poderiam por gentileza me dar um help???
Address 02: Auto Trans (J217) Labels: 0AW-927-156.clb
Part No SW: 8K0 927 155 AA HW: 0AW 927 156 G
Component: 0AW 20TFSIRdW H02 0004
Revision: --H02--- Serial number: 0000000018
Coding: 000001
Shop #: WSC 06325 000 00000
ASAM Dataset: EV_TCMVL381 A01015
ROD: EV_TCMVL381.rod
VCID: 72EB3C43A55AFA8E927-8027
1 Fault Found:
2225 - RPM Signal from ECU
P0727 00 [108] - No Signal
Intermittent - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 2
Fault Frequency: 194
Mileage: 86600 km
Date: 2014.11.06
Time: 18:00:45
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 AL HW: 8K0 907 064 AL
Component: BCM2 1.1 H80 0143
Revision: 00002001 Serial number: 0114592682
Coding: 011E062200390084013001
Shop #: WSC 03264 105 79789
VCID: 7AFB1463F52A82CEDA7-802F
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS034 H06 0037
2 Faults Found:
02615 - Fuel Tank Cap; Lock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:03
02616 - Fuel Tank Cap; Unlock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:14
Thursday,06,November,2014,19:14:45:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WAUJF68K19A140574 License Plate:
Mileage: 86600km-53810mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 2E 42 46 47 52 53 55 56 62 72
77
VIN: WAUJF68K19A140574 Mileage: 86600km/53810miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (MSTR-CDNB) Labels: 06H-907-115-CAB.clb
Part No SW: 8K2 907 115 Q HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0003
Revision: E1H14---
Coding: 0104100C02070160
ASAM Dataset: EV_ECM20TFS8K2907115Q A01005
ROD: EV_ECM20TFS0118K2907115AH.rod
VCID: 3D71DF7FAC8475F6BF5-8068
No fault code found.
Readiness: 0010 0001
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Mileage: 86600 km
Date: 2014.11.06
Time: 18:00:45
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AA HW: 8K0 907 379 AA
Component: ESP8 front H04 0060
Revision: -------- Serial number: --------------
Coding: 260500
VCID: 78FF0E6BCB2690DEAC3-802D
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Revision: 00002001
Coding: 010100
Subsystem 1 - Part No SW: 8T0 959 754 HW: 8T0 959 754
Component: FBSAUDIB8 IDG H37 0060
Subsystem 2 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: ELVAUDIB8 H36 0041
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 T HW: 8T1 820 043 T
Component: KLIMA 1 ZONE H06 0140
Revision: A0000000 Serial number: 0116.09.081266
Coding: 64002000
Shop #: WSC 06342 000 00000
VCID: 428BAC83DD7A0A0EC27-8017
Address 09: Cent. Elect. Labels: None
VCID: 55A167DFBCF48DB6975-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1B59N6
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C77D27BB79E7CFE88B-8069
Crash sensor for side airbag; driver side:
Serial number: 6334MSME4114542D7
Crash sensor for side airbag; passenger side:
Serial number: 6344MSME41126D7FN
Crash sensor for side airbag; rear driver side:
Serial number: 6352QSME230E1B3AL
Crash sensor for side airbag; rear passenger side:
Serial number: 6362QSME4C0C5232I
Crash sensor for front airbag; driver side:
Serial number: 63732SME710C2C280
Crash sensor for front airbag; passenger side:
Serial number: 63832SME7933250E0
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90319HIL000FT
Coding: 000036
VCID: 3D71DF7FA48475F6BF5-8068
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 900 HW: 8K0 920 900
Component: KOMBIINSTR. H17 0224
Revision: 00000000 Serial number: 9DL25PR98
Coding: 0F0708000200000C060000
Shop #: WSC 00266 659 91222
VCID: E7DDDD1716988F26B59-80B2
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 H HW: 8T0 907 468 H
Component: GW-BEM 5CAN H06 0094
Revision: 4GB20042 Serial number: 4200G088288172
Coding: 000303
VCID: 4683B093F152362EEEF-8013
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
Address 2E: Media Player 3 (R199) Labels: 8T0-035-785.clb
Part No SW: 8T0 035 785 HW: 8T0 035 785
Component: SG ext.Player H06 0210
Revision: 00000000
Coding: 020202
VCID: F8FF8E6B4B2610DE2C3-80AD
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 B HW: 8K0 959 793
Component: TSG FA H10 0170
Revision: Serial number: 0000007748178
Coding: 011002205000410001
VCID: 3F8DA577AE8867E6AD9-806A
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:14
Address 47: Sound System (J525) Labels: 8T0-035-223-ASC.clb
Part No SW: 8T0 035 223 AB HW: 8T0 035 223
Component: DSP STD H07 0220
Revision: S2100000
Coding: 0203010102
VCID: 6ED32833B962DE6E76F-803B
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 B HW: 8K0 959 792
Component: TSG BF H10 0170
Revision: Serial number: 0000007758706
VCID: 3E73D873A9826EEEA6F-806B
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 E HW: 8K0 907 801 E
Component: EPB Audi B8 H05 0060
Revision: 00000003 Serial number: 00000000230013
Shop #: WSC 00000 000 00000
VCID: 3169F34F68DC81962BD-8064
Address 55: Xenon Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000004
Shop #: WSC 06324 000 00000
VCID: 3467FA5B57CEB4BE40B-8061
Address 56: Radio (J503) Labels: 8Tx-035-1xx-56.clb
Part No SW: 8T1 035 195 K HW: 8T1 035 195 K
Component: Symphony3 US H02 0211
Revision: 00000004 Serial number: AUZ5Z4H1046477
Coding: 04020082010185010159070800
Shop #: WSC 06325 123 12345
Subsystem 1 - Part No SW: 8T0 919 603 A HW: 8T0 919 603 A
Component: Display
Address 62: Door, Rear Left Labels: None
No Faults Found
Address 72: Door, Rear Right (J389) Labels: 8K0-959-794.clb
Part No SW: 8K0 959 794 A HW: 8K0 959 795 A
Component: TSG HR H06 0170
Revision: Serial number: 0000007752632
Coding: 010002204000210001
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8T0 862 335 C HW: 8T0 862 335 C
Component: FSE_256x BT H33 0550
Revision: 00000000 Serial number: 00000005033879
Coding: 0010390
VCID: 3A7BD46375AA42CE9A7-806F
End
Desde já agradeço a todos pela ajuda!!!!!
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Mileage: 86600 km
Date: 2014.11.06
Time: 18:00:45
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:14
77
Revision: E1H14---
Coding: 000001
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Mileage: 86600 km
Date: 2014.11.06
Time: 18:00:45
Coding: 260500
Revision: 00002001
Coding: 010100
Coding: 64002000
No Faults Found
Coding: 000036
Coding: 000303
Revision: 00000000
Coding: 020202
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:03
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 64
Mileage: 86586 km
Time Indication: 0
Date: 2014.11.06
Time: 13:40:14
Revision: S2100000
Coding: 0203010102
Coding: 0000004
Component: Display
No Faults Found
Coding: 0010390
End
