Diego Miranda
Pessoal boa tarde, help-me
A3 turbo 180 03/03 tiptronic
segue o log e as duvidas, a minha 180 tem 2 sondas, qual delas deu defeito?
a banda larga ou a outra?
e ajuda do Marinho caixas, o que eu faço galera?
Friday,10,June,2016,15:04:58:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: License Plate:
Mileage: 128750km-80001mi Repair Order:
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2003))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
VIN: Mileage: 128750km/80001miles
Address 01: Engine Labels: 06A-906-032-AJQ.lbl
Part No: 06A 906 032 HR
Component: 1.8L R4/5VT G 0001
Coding: 27550
Shop #: WSC 00000
VCID: 75E1075F4F34EDB6B75-5072
93UMC28L934008339 AUZ7Z0B2296607
2 Faults Found:
17524 - Oxygen (Lambda) Sensor Heating; B1 S1
P1116 - 35-00 - Open Circuit
17511 - Oxygen (Lambda) Sensor Heating; B1 S1
P1103 - 35-00 - Performance too Low
Readiness: 0010 1101
Address 02: Auto Trans Labels: 09A-927-750.lbl
Part No: 09A 927 750 AN
Component: AG5 Getriebe 09A 0230
VCID: 77FD0D5755389FA6A59-5072
1 Fault Found:
00300 - Transmission Fluid Temp. Sensor (G93)
27-10 - Implausible Signal - Intermittent
Address 03: ABS Brakes Labels: 1C0-907-37x-ASR.lbl
Part No: 1C0 907 379 K
Component: ASR FRONT MK60 0103
Coding: 0018945
Shop #: WSC 00000 785 00200
VCID: 326BFC43AEDABA8E527-5000
No fault code found.
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 K
Component: A3 KLIMAAUTOMAT 0105
Coding: 00040
Shop #: WSC 00001
VCID: 306FF64BF0D6889E243-2580
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 L
Component: Airbag Front+Seite 7008
Coding: 00104
Shop #: WSC 00001
VCID: 479DBD9765582F26159-5000
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 932 M
Component: KOMBI+WEGFAHRS. VDO D11
Coding: 00544
Shop #: WSC 00278
VCID: 3A7BD46326AA42CE9A7-5000
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 G
Coding: 14190
Shop #: WSC 00278
VCID: 3979CB6F23AC49D693D-4DD6
2 Faults Found:
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00955 - Key 1
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Coding: 00001
Shop #: WSC 00001
VCID: E0CFC60B60B6F81E743-4A9C
1 Fault Found:
01381 - Alarm triggered by Anti-Theft Sensor; Rear Right
35-00 - -
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00013
Shop #: WSC 00001
VCID: E5C1D71F7F949D36875-5072
Address 56: Radio Labels: None
Part No: 8L0 035 195 J
Component: symphony II NP2 0050
Coding: 05001
Shop #: WSC 00001
VCID: 3561C75F0FB4ADB6775-4DD6
End ---------------------------------------------------------------------
VIN: License Plate:
Coding: 27550
Shop #: WSC 00000
2 Faults Found:
1 Fault Found:
Coding: 0018945
Coding: 00040
Shop #: WSC 00001
Coding: 00104
Shop #: WSC 00001
Coding: 00544
Shop #: WSC 00278
Coding: 14190
Shop #: WSC 00278
2 Faults Found:
35-00 - -
00955 - Key 1
Coding: 00001
Shop #: WSC 00001
1 Fault Found:
35-00 - -
Coding: 00013
Shop #: WSC 00001
Coding: 05001
Shop #: WSC 00001
